need a shroud for a 47 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2013, 06:20 AM
I need a shroud for my 47 ford , running mechanical fan. bought one for a 47 ford didn't fit. need one 21 inches wide and 19 inches tall, where do i start, i found one place that will custom build me one. Got a friend looking at salvage yards. This is a pretty small shroud, probably have to have it custom made.
Input?
Old 11-09-2013, 06:33 AM
delawarebill's Avatar
shourd
ck ebay?? but if all fails how about homedepot/lowes.. get some sheet metal, bend to your needs and pop rivet "L" brackets to attach to rad..
Old 11-09-2013, 06:38 AM
Banned
https://www.google.com/search?q=1947...ient=firefox-a
.walkerradiatorworks.com/fan_shrouds.cfm
Old 11-13-2013, 10:41 AM
46highboypu's Avatar
Last journal entry: More pin stripes
I'm using one from Speedway, it's universal of course. Actually it's a chromed band about six inches wide that you shape around your fan and fasten with ties. Seems to work well for me.
Name:	rod journal 479.JPG
ID:	98306   Click image for larger version
Name:	rod journal 480.JPG
Old 11-13-2013, 06:39 PM
59 wagon man's Avatar
summit has a great kit i just used
Old 11-14-2013, 12:59 AM
JeffB's Avatar
Input?
Your radiator is about the same size as an early Mustang 1967-69 you could do this:Junkyard Upgrade - Dual Electric Fans - Ford Muscle Forums : Ford Muscle Cars Tech Forum or this: 1967 1968 1969 Mustang Radiator Fan Shroud Ford Tooling Great Repro on Sale | eBay Radiator size is here:3 Row w O EOC w TOC Performance All Aluminum Radiator for 4 7 5 0 5 8 V8 Gas | eBay
Old 11-27-2013, 10:37 AM
416Ford's Avatar
One of the best TECH addition on the HAMB covered this. It an older thread but a good one.
If you want to do a custom shroud.
Building your own shroud
Old 11-27-2013, 11:05 AM
Rick 5150 69's Avatar
You may try Walker Rad works here...
Fans & Fan Shrouds by Walker Radiator Works
or here for blank shrouds cut your own hole...
http://www.yogisinc.com/index.cfm/pa...6/prd13486.htm
Fan shroud VS no fan shroud 66Ponty Hotrodding Basics 15 03-23-2013 06:18 AM
Should i un-shroud the valve??? 74chevyflat Engine 17 05-21-2010 05:21 PM
fan shroud 36 ford p/u redcoyote General Rodding Tech 3 01-14-2010 06:01 PM
Electric Fan-Shroud or no Shroud? Cole Engine 12 02-05-2009 10:35 AM
Radiator Shroud JamesRS Engine 4 08-17-2006 02:24 PM
