Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need skilled info
Old 01-05-2013, 07:19 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
If you do a little porting on the exhaust side,bowl work and install 2.19 intakes and 1.88 exhaust valves you will make very good power.This is not over doing anything. I did similar work to my oval heads when I had my 1980 Camaro. worth the money
