need skilled info - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2013, 07:09 AM
need skilled info
ok im a new guy been reading alot on 781s im building a 79' 454 looking for a good setup on my 85'swb its gonna be a weekend show off .my run the strip few times.( its got comp lifter n cam package 292/550.im lookun to build a dependable street motor and i live across from drag strip .im needing info on rebuilding my heads but not lookin to replace my bottom end.was thinkin of uping the valve size like i read but dont want to over do it
.im 26 this is my first build. i need to know what to tell the shop to do to the heads. please help
Old 01-05-2013, 07:19 AM
vinniekq2's Avatar
If you do a little porting on the exhaust side,bowl work and install 2.19 intakes and 1.88 exhaust valves you will make very good power.This is not over doing anything. I did similar work to my oval heads when I had my 1980 Camaro. worth the money
Old 01-05-2013, 08:26 AM
ok, cool i live se of dallas any good shop u recomend?
Old 01-05-2013, 08:36 AM
BOBCRMAN@aol.com's Avatar
Here is basic for big valve 049-781 heads.
Clean, check for cracks/warp.
Check valve guides for wear. If worn, repair with bronze liners.
Shorten guides and cut for performance seals.
Serdi cut intake seats for 2.19 valves.
Bowl hog to blend.
Serdi cut exhaust seats for 1.88 valve.
Bowl hog to blend.
two angles on valves
Install rotator eliminators.
Install valve seals.
10 degree +.100 retainers
Set springs to spec height.
I just did six of these heads for inventory last week.
For economy sake. Comp Products has a good price for aftermkt seals and a special on valves on the broom sheet.
Good prices on springs.
I bought hundreds of stock length stainless 2.19 and 1.88 valves. On a deal, several years ago. If you can buy +.100 valves reasonable, use them rather than the +.100 retainers. These heads, stock, have short valve springs.
If a mild cam with single springs. You can save money by not cutting guides and use 455 Buick valve seals. Also TSC stores sell a gold colored 5/8" washer in bulk hardware. That, when used in pairs, work good as rotator eliminator.
Heep guide to valve stem reasonably tight. Loose guides along with large valve heads= dropped valves. A historic BBC problem.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
1Gary (01-05-2013)
Old 01-05-2013, 08:40 AM
Old & Furious
How many miles on the bottom end. If you pull the heads off the motor you will probably end up rebuilding the engine if its high miles and never been rebuilt. I would be suprised to see a big block with perfect bores from 1979 and still perfect.
The heads are very heavy, alum heads will take a good chunk of wieght off the car. And will be bolt on ready AFR has some nice heads for 454. By the time you get the heads back you will have at least 500 to 1000 bucks in them unless they are fresh already. Between port work and new parts and replacing any burnt or bad valves guides and seats. You will not be far away from the price of great alum heads and get the wieght along with the large flow.
need skilled info
I know you said you don't want to replace your bottom end. But the chambers on the 781 heads are at least 118cc. So it would be nice to know if the pistons are flat top or domed. For an example KB pistons have three different size domes -12cc, -25.5cc and -43cc. With the 781 heads you would need a -12cc dome to have a 9.173 compression ratio which would be ideal with pump gas. The compression ratio with a flat top piston would be 8.233 a little on the low side.
Old 01-05-2013, 04:59 PM
well im not sure of miles on it i believe its stock pistons i guess they r flat top they have s mall circle in the center. i have a set of luntinedouble springd that i got with all of the parts. how do i know if the springs r the rite ones to use?
Old 01-05-2013, 07:58 PM
need skilled info
I am sorry but you have a set of dished pistons in the bottom end. If you were to use the 781 heads you would have a compression ratio of 7.487. With this setup you will need to use a RV cam. Something like X4 254H. You will have good low end and mid-range power. The engine would have around 369 hp @ 4500 rpms and 510 lbs torque @ 2500 rpms. This will be fine for shows but not the track. BTW it would be your best interest to sell all the COMP .550/292 camshaft parts.
Old 01-05-2013, 11:18 PM
have n second thoughts on the bb .im running a 87'block n heads now its a 355 im really thinking about just makin it tbi or tpi (i love the throttle response) its fresh maybe 2k miles on motor. its got comp cam n lifter setup.I have never been a fan of carb.im runnin a 750 holley double pumper was told its to much for my motor ??? can i make close to 500hp with the sb? whats better tpi/tbi??
Old 01-05-2013, 11:26 PM
vinniekq2's Avatar
big difference between a 500 hp 355 and a 500 hp 460
yes you can make 500 hp
Old 01-06-2013, 12:19 AM
so whats better tpi/tbi?
Old 01-06-2013, 12:36 AM
when u say diff u talkin ft lbs
and waight. i got 355 and 454 not 460
Old 01-06-2013, 01:05 AM
Vinnie, I think you had better explain to him what it will take and cost for a 500hp tbi or tpi engine if he didn't want to rebuild the BBC.
Old 01-06-2013, 11:26 AM
only reason for second guess n is 355 is fresh and is alot less weight.yes what more could it take to make near 500hp?
Old 01-06-2013, 11:35 AM
one more stupid ?? the 87' heads on the small block that have the valve covers that mount with bolts in center of the covers .. r they considered vortec heads???
please help i need info on a pontaic carburator 455, no info online! COUGARPOWER Engine 7 09-14-2009 12:45 AM
Wages for skilled, experienced auto paint/body tech? shad9876 Body - Exterior 17 09-29-2008 07:18 PM
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
Skilled Help Needed!!!! riffs3 Suspension - Brakes - Steering 1 07-18-2002 06:06 PM
