Need some 307 advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-31-2012, 01:54 AM
DoubleVision's Avatar
If you want a 327 you have part of what you need to build one.
A 307 has the bore of the 283 at 3.875 inches and the stroke of the 327 at 3.250 inches. Get a 350 block, get 327 pistons pressed on your rods. Throw the crank in the 350 block and you have a 327.
However, I like 307's. And they can make good power as well as good fuel economy if done right. You have $1200 to play with, providing the engine doesn't need a complete rebuild and your looking to step up the pep of the little mouse and not making it into a fire breather then it's easy.
First off, get a set of heads off a 305, the 416 casting.
These heads have 1.84 intake and 1.50 exhaust valves and a small 58cc chamber. This will give you right at a 9.5:1 compression ratio which is ideal for pump gas. Next install a summit racing cam part number SUM-1065.
This cam has duration @.050 .216 intake and exhaust and .454 lift.
Get a set of valve springs to match the cam.
Add a double roller timing chain. A set of small tube 1.5 inch primary headers. Dual exhaust with H pipe into mufflers of your choice.
Retain the intake, carb and ignition system you have.
This combo will not only give it excellant low end torque but it'll also improve the fuel economy. The cam has a slight lopey idle so it'll sound good.
If you find a set of 416 heads that don't need alot of work, then you'll have a good bit of your cash left over. If the heads need guides then it'll get a little more expensive. Either way, you'll still come out to the good money wise.
The 307 got a bad rap for 2 reasons. Number 1 is chevy never made a performance version of it. It was strictly a economy engine. number 2 is because chevy had a bad run of cams during a model year so the cam would go flat and usually take out the rest of the engine with it. However, it's still a small block chevy, given the right parts it'll come alive and run very nicely.
The Following User Says Thank You to DoubleVision For This Useful Post:
rube'68'03 (10-31-2012)
  #17 (permalink)
Old 10-31-2012, 07:34 AM
In the late 70's and early 80's dirt track super modified racers in Tx and Ok were forced by class rules to run 311's (.030 over 307). Reher and Morrison paid their rent grinding heads for them. There's still people in that part of the country that know how to make a 307 go like stink. On the other hand a 350 wouldn't hurt your value one bit.
The Following User Says Thank You to hpete For This Useful Post:
  #18 (permalink)
Old 10-31-2012, 07:58 AM
If you're planning on reselling said truck, pull the 307 and dunk in a 350, your resale will go up. Most buyers will try to talk you down due to the supposed bad 307 (which since you would be changing the cam and timing set, would be perfectly fine. If you DO opt for the 350, keep the 307 for another hot rod project and tell everyone its a 283, which all the retro guys love.
If you build the 307, DV's advice is spot on. Realistically you could put 3.73s in the back of your truck, and a 700r4 or 200-4r overdrive automatic (or a T5 or 833-OD stickshift) and have an absolute riot for a street truck
The Following User Says Thank You to AutoGear For This Useful Post:
  #19 (permalink)
Old 10-31-2012, 08:19 AM
DV- the majority of the 416 heads im finding are 64cc. How much of a diffference will that play then the 58cc you suggested?
  #20 (permalink)
Old 10-31-2012, 08:31 AM
Banned
FWIW, IMO those 416 heads aren't worth playing with. If you have to use OEM heads just get a set of camel humps or Vortecs and angle mill them 1 degree. You'll have your compression and a better runner (especially the exhaust).
  #21 (permalink)
Old 10-31-2012, 10:40 AM
vinniekq2's Avatar
you cannot disguise a 307 as a 283. and what ap said I said before and still think that is the easiest.camel bump 194s are cheap,port the exhaust side if you have spare time
  #22 (permalink)
Old 10-31-2012, 01:12 PM
to the majority of normal folks; if you put a factory aircleaner on there with "283" on it and some corvette finned aluminum valvecovers, they'd accept it.
I for one don't spend my time at carshows looking at casting numbers and other specifics. A smallblock is a smallblock to most people.
A purist numbers matching guy would know, or an engine builder, but if you're building a 60s era t bucket, does the displacement matter?
To the OP: you have several directions to go, just take stock in your abilities and evaluate the parts you have on hand carefully. You'll have a nice (307, 327 or 350 powered) truck you can be proud of.
There was a guy around here (HR.com) that had a 65 nova with glass fenders, hood & bumpers; little 14" cragars, M20 and a 307-based 310 out of a roundy round car. It has something like a 262H cam in it, manual brakes, manual steering and it was a HOOT to drive.
  #23 (permalink)
Old 11-01-2012, 12:16 AM
All the info I get says the 416 is 58cc and that's what I've been going by for the past 20 years. If they were 64cc then the compression ratio on a 305 that these heads came on would be dirt low.
Going with a set of camel humps isn't a bad idea, but you have to realize, if you find a set that has to be rebuilt you'll be sinking $600 in them just to bring them to spec. If they need rebuilt they'll need to be magnafluxed to check for cracks, milled to flatten the decks. Also will need valve guides, possibly new valves, hardened exhaust seats and of course the basic valve job. Vortecs aren't a bad idea either by no means. You can usually get a set for around $600 ready to bolt on. However you'll need center bolt valve covers, You will need a Vortec intake, you won't be able to use the intake you have, and you'll need a set of self guiding rocker arms. By the time you add that up, plus the price of the cam and timing set all $1200 will be gone and you won't even have a set of headers for it yet. I suggested the combo I did because it's cost effective to the parts you have and it will help performance. No it won't be a fire breather, but it will have great low end torque which is just what a street truck that isn't going to see any track time needs.
rube'68'03 (11-01-2012)
  #24 (permalink)
Old 11-01-2012, 05:27 AM
Last journal entry: was hoping for better than this
if you don't want to swap in a junkyard engine.. and rather build off what you have for now.. and build what you want for it later..
here is what I'd do...
find a 305HO in a monty SS or t/a,firebird,camaro..
in the SS the eighth vin # will be a letter "G" .. the foby it might be an "H" have to check on that..
grab the heads and if you want to run a q jet carb the intake.. if you'd rather a holley/etc get a edle intake used..
the 305"g" engine heads are the best flowing 305 heads.. and the chamber side is tiny iirc 55 cc.. that 'll get the compression up to about 8.9/9.1
in that 307.. add in a smallish cam (think 305 truck towing cam)
and it'll wake that 307 up..
best part .the parts are dirt cheap..
you can get 300hp out of this set up...
good luck... the swaping in a junkyard 350 isn't a bad one.. but food for thought..
g.m. sells the 96-02 truck vorect 350 all new.. for 1999.oo and with 1200.oo budget,, save a little more and you are there..
depending on where your at.. pace.com or s.d will have the new engine on the cheap
add intake and carb and headers and you have a stroung new 325-350hp 350 small block thats all new parts... with a roller cam...
if I keep a small block in my truck (71 c-10) this is the engine I'll install.. you can't build one for what g.m. sells it for..
I have a 496(489) in basement that I'm fighting with do I, or don't I..
good luck.. with whatever you choose..
oh and welcome
The Following User Says Thank You to E.Furgal For This Useful Post:
  #25 (permalink)
Old 11-01-2012, 05:30 PM
Besides your basic summit racing and jegs, does anyone suggest a parts dealer?
  #26 (permalink)
Old 11-01-2012, 05:40 PM
vinniekq2's Avatar
most parts stores are capable of supplying parts. We have Lordco/TnT/mopac and many more. If you know what you are buying then put one company against the other and get a deal.Any local engine builder might fix you up with jobber parts. or buy quality parts example trw/speed pro pistons etc.
  #27 (permalink)
Old 11-01-2012, 06:44 PM
ALCON- found this article very interesting. Super chevy took a 1968 307 (exactly what i have) and did a nice makeover on it. Problem im having is when i do any investigating on the heads they used, every source is telling me it wont work on my motor. Any ideas? Plus the info i am gathering on the cam says its a 4X4 part. Summit says its either for off roading or towing?????
  #28 (permalink)
Old 11-01-2012, 06:45 PM
307 Chevy Dyno Test - Super Chevy Magazine
Heres the link ^^^
  #29 (permalink)
Old 11-01-2012, 06:55 PM
vinniekq2's Avatar
If you read my first post? Thats what I was saying in the beginning.so many people have offered other ideas. 1200 bucks will only buy so much,,,
300 hp is what I would expect
  #30 (permalink)
Old 11-02-2012, 03:56 PM
Ok, so i found a set of 416's for 25$. Couldnt help myself. Im going to take it in for testing and cleaning and thought of getting all new valves. What is the suggested valvles, and with what cam/lifters. Im planning on getting steel tip roller rockers and replacing the lifters.
a different 307 sbc build, need some advice v8fbrx7 Engine 97 07-25-2012 12:53 PM
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 03:21 PM
Chevy 307 - POB 307? El C Engine 13 10-15-2009 04:05 AM
Seeking advice on rough idle; "Y" code 307.. Oldsmolac911 Engine 1 11-14-2002 12:25 AM
