Need some 4spd info. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2006, 03:44 PM
I'm new to 2wd trannys, if U need a gear box for your rock crawler I'm your man! But now I have a 2wd '71 Chevy truck with the stock 3spd, converted to a floor shift. I need a 4 or 5spd tranny for it, but I want to use as much 'yard parts for the swap as poss. What can I put in it without to much $$ or a 2 week ordeal to put it in? It's got the 305 V8, it's a 1/2T, I'm not sure what the rear gears are but I think it's around 3.73 just from the feel of it. This thing will NEVER see any more the 300HP, so I don't need bomb proof, just eazy to get and put in.
Old 05-19-2006, 05:15 PM
Jmark's Avatar
How about a 4 speed with granny first?
This guy has one from the board here.
Old 05-19-2006, 07:11 PM
That tranny it DA ****!! for an off road truck, but it's big and stiff for a hot rod. And the gears are a WIDE 2. I'm looking for more of a car type tranny. But thanks for the heads up on that ;-)
Old 05-19-2006, 07:15 PM
Saginaw 4-speed comes to mind. It's available with 4 different gear-sets, with low gears of 3.50, 3.11, 2.84, and 2.54:1. They're found in GM cars from '66 up, usually behind a small-block or a 6, but some Vega-based cars with 4-cylinders had them. Length is the same as the Saginaw 3-speed that you probably have.
Saginaw can be ID'd by an iron case with a side cover that has all 3 shifter shafts in it. Gear ratio can be determined by the number of annular rings around the splined area of the input shaft. They're not the strongest transmissions around, but I've been beating on one (3.11 version) with a mild 350 for a long time with no problems. Stock 10.4" clutch & street tires, though.
Here's a site with parts & ID info: http://www.dandltransmission.com/saginaw.html
If you can't find a suitable 4-speed shifter, you can use your 3-speed shifter for the forward gears, and rig up a separate lever for reverse.
Old 05-19-2006, 09:56 PM
iv e got a getrag 5 speed but would probably be more trouble than what its worth and i have two 57 chevy 3 speed and a granny 4
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
ROD INFO floating versus pressed GoneNova/406 Engine 15 12-02-2004 03:03 PM
windsor info Blag Engine 1 04-24-2003 08:08 PM
info on turbocharging engines crshrmn3 Engine 4 12-20-2002 12:27 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
