Need some advice about two possibe trucks set ups - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2011, 03:00 PM
VR4 power
The name is Sean i'm new to the website and i'm hope you guys could help me with some trucks ive been looking into... i have been looking into some 1950's ford f1's and Chevy short bed pick ups that i would like to work on and turn into a street rod with some serious power
i found a ford f1's that i like and have been considering putting a 2000 mustang cobra svt engine in it and twin turbo it along with a blower under the hood if this possible ? i believe it is Ive heard people say that it can be done but im looking for more information on it and was hoping some one on here would know it was for sure... i basicly want to build a ford gt engine into a ford f1
The 55 Chevy short bed i like i want to put a corrvette z06 engine in it fuel injected twin turbo and running a blower as well. if this is posssible... please let me know what you think and let me know if these are even possible
Old 01-03-2011, 03:08 PM
kleen56's Avatar
You have some good ideas but let me tell you what your in for first. The frames on the F1's or F100's are no way capable of handling the power of twin turbo cobra engines, etc. In order to have a motor with that type of horsepower, etc, the frame would need to be boxed in. A conversion kit needs to be made as well. If your considering a ground up project, it will work fine. You'll have to consider different types of front ends as well. The stock trucks came with a straight axle on leaf spring front end. Most guys opt for the Mustang II IFS type front end. They have kits out there for the conversion. I recommend you study up on what needs to be done. Remember, the old trucks are over 50 years old and weren't designed to have motors with over 300 horsepower in them.
Old 01-03-2011, 03:14 PM
VR4 power
i know that the truck wont be able to handle that power stock and that i will have to box the frame and do alot of work to allow it to handle it and etc the truck is actually going to be a ground up project that my father and myself will be doing our selves but what kind of front ends would you recommend useing?
Old 01-03-2011, 03:26 PM
I would recommend Chevy.
Old 01-03-2011, 03:35 PM
kleen56's Avatar
There several option and it depends on your taste. Some people like the straight axle which is simple and can be converted to disc brakes on the front. The ride isn't as good as with a Mustang II front. The Mustang front end is a popular choice amongst street rodders and is not too complicated of an install. It comes with the disc brake and suspension all in one package. Do you plan on running power steering? Then you'll have to decide on steering boxes (Toyota 4X4) is popular on older trucks. Some people go with the Volare front end as well. I kept the straight axle in my 56 F100 because I like the nostalgia look and feel. I used different leaf springs to lower the truck along with a drop axle straight axle, which drops the front end pretty low. The ride isn't as smooth or precise as the Mustang II, but works for me. Check out some of the Classic Truck magazines or Truck chat sites, and then make a decision. If I was doing a frame up? I'd probably go with the Mustang II and be done with it. That's only my opinion!
Old 01-03-2011, 05:07 PM
VR4 power
well the truck wont be a daily driver but it will be driven quite a bit i hate when someone has a truck or any vehicle at that and it just sits it drives me crazy
but i am going to for sure have power steering in it and the smoothness of the ride is important but yet again isn't the most important thing to me as long as it it doesn't jar me everywhere driving im fine with it... i want to go with the same look they gave the f100 in the expendables for the most part except the duel exhaust is going under the doors just in front of the rear wheels and Ive been strongly considering doing a flame kit too just for kicks
http://www.google.com/imgres?imgurl=...t:429,r:14,s:0
Old 01-03-2011, 06:14 PM
AntnyL's Avatar
A Mustang II IFS kit is a solid choice (that's what I put into my Chevy truck), but a rebuilt Camaro or Nova clip makes for a nice ride too. Power steering really isn't a necessity as long as the front suspension geometry is good. Mine is actually TOO easy to turn, and I run fat tires up front. Boxing and x'ing the frame to add rigidity is wise too with the proposed power that you're considering. The stock frame would twist like a pretzel and wrack your cab easily. The rear suspension will need LOTS of attention to transform all that power into forward motion. With the sort of power you're talking about, I'd opt for a full cage and tie the entire chassis together, fore to aft, or, opt for a custom chassis ala Art Morrison or equal. Anyway, just some rambling thoughts. Hope this helps.
Old 01-03-2011, 06:58 PM
VR4 power
They way the roads are out where I live at power steering is a must and a smooth ride is just as important but it's nothing that I haven't grown up with out and can't handle with out but I'm going with a full cage no matter what truck I get because well plain and simple it's like you said it's just to much power and it will just trash it if I don't , and the suspension is the one thing that has crossed my mind quite a bit and a custom chassie like you said is more then likely what I'm going to end up doing
technical comparision of MAN TRUCKS & AMW TRUCKS,INDIA santhoshkumaryn Introduce Yourself 2 06-15-2009 09:55 AM
Hot rod trucks deebee53 Introduce Yourself 1 10-21-2007 07:59 AM
trucks wildcrazy1970 Introduce Yourself 2 10-11-2005 08:24 AM
trucks jb80proof Hotrodders' Lounge 0 05-26-2004 08:07 PM
Trucks TV ??? classic_chevy_guy Interior 14 11-06-2003 05:09 AM
