Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Some Advice Before Shooting FeatherFill G2!!
Old 05-15-2011, 11:33 AM
tech69 tech69 is offline
put up or shut up
I guess I should have noted I "usually" use a cap full per 12-14 oz for a 1.8 tip and in hotter weather. In normal weather I use a cap full for 24 oz. With a 2.0 tip you won't need as much. Always good to start with less and then add more if you find it dry on the edges, but don't add too much. Also, not only is gonna contribute to less dry spray it will slow the curing process in your gun and you won't have to turn up your pressure if it starts to thicken in the gun.
