Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Some Advice Before Shooting FeatherFill G2!!
Old 05-15-2011, 06:34 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I'd return it....and get ANY 2k urathane primer instead. it sands like a brick its hard to get out of the gun and always has a rough undercoating like texture,plus is hard to get the hardener just right for smaller jobs.at least use a gravity gun if you do use it,you'll end up throwing a siphon gun and dont forget to clean the gun when your done if you ever want to use it again....I cant think of ANY good reason to use it or any advantage it has over any 2k primer even the absolute cheapest ones...especially after using a good epoxy.It also cracks and chips easier than anything else....Try sanding it with 320 sometime .... Sorry but thats what I truely think of it and I like evercoats products...
