I use 1.8 cause I feel my body work is good enough where I can use a small tip and it saves primer but a 2.0 is better, I admit. When it's in the 80's+ I use a full cap full of lacquer thinner for every 12-15 ounces and this greatly reduces dry spray. Better to start on the side with less and evaluate how it sprays immediately. If it's too dry at the edge of your fan add more thinner and mix it in your cup. Any gun is fine at the recommended psi. Mix less in hotter weather. Not a great idea to add less hardener and mix a bunch. If you're doing a complete and mixing individual 24 oz cups or above, AND it's hott, completely clean your gun out after two mixing/ spray sessions or you will start shooting out little hardened pieces of primer. WHen it's not hot you can spray your whole car mixing a couple times without cleaning your gun til the end, but not in hot weather. It's very spray friendly. Doesn't run and is not finicky as a 2k.
I guess I should have noted I "usually" use a cap full per 12-14 oz for a 1.8 tip and in hotter weather. In normal weather I use a cap full for 24 oz. With a 2.0 tip you won't need as much. Always good to start with less and then add more if you find it dry on the edges, but don't add too much. Also, not only is gonna contribute to less dry spray it will slow the curing process in your gun and you won't have to turn up your pressure if it starts to thicken in the gun.
I shot it over SPI on my car. That stuff is THICK and pretty hard to sand relative to the SPI epoxy Primer. If you don't get it to lay down pretty smooth, your shoulder is gonna hate you. The gun I used couldn't handle it. It came out irregularly and made it a bear to sand.
I'd return it....and get ANY 2k urathane primer instead. it sands like a brick its hard to get out of the gun and always has a rough undercoating like texture,plus is hard to get the hardener just right for smaller jobs.at least use a gravity gun if you do use it,you'll end up throwing a siphon gun and dont forget to clean the gun when your done if you ever want to use it again....I cant think of ANY good reason to use it or any advantage it has over any 2k primer even the absolute cheapest ones...especially after using a good epoxy.It also cracks and chips easier than anything else....Try sanding it with 320 sometime .... :sweat: Sorry but thats what I truely think of it and I like evercoats products...
I agree with the chipping part but it has way more fill properties than a 2k, and a 2k is way more finicky. It also sands better than 2k's hands down. I think poly primer is best served for getting it straight with two rounds, or however long it takes a person, THEN top coat it with a 2k primer for your final sanding.
It sprays fine if you know how to use it. His problem with it is not the product, I can guarantee that.
Dont you use bondo ,tech??? What situation would anyone ever need that much fill??? I will say one good quality it has,it dont shrink...at all.....Today I was at the paint store and saw feather fill in a 4:1 mix ratio ..must be new....maybe its easier to sand now too...I know they've changed the formula a few times since used it last ...
I am just looking to shoot some Polyester and long board blocking it to mainly help straighten/flatten some panel "rolls/waves". I thought that Poly would be easier and faster than "spread-on" filler. I've already filled and feathered the low "spots' and "dents".
A lot of top restoration shops use it and my bodywork is fine. We're talking to take care of stuff your hand can't feel, and hand feel is for dealing with mudwork. Straightening beyond that comes from primer. My work is as straight as anyones and you can get there quicker with featherfill. By the time the straightening is done, if you know what you're doing, most of the primer is on the floor and it's not excessively thick. Topcoating it with a 2k gives it a pliable surface for rock chips. So in a sense you're right but you'll get that better end result much quicker implementing a poly primer in your early primer apps.
If your set on using a spray poly you may want to try some Omni MP243 sprays just like a 2K primer. Believe me I have tried most of them and by far this is the best one hands down. Blocks out real nice with 180 grit as well.
If your not using bondo and poly putty for that type of work and
If your set on using it ,go ahead .We call it spray bondo,over here..the guys that have used it and like it have told you about everything you need to know,bigger tip size and thinning will be your biggest help but be double sure to get the ratio right when mixing and be sure to tape everything up well as you would with any primer (overspray is tough to clean up with any primer) and a guide coat before blocking will be your savior...
Maybe you should have asked :whats the best primer to use before you bought the feather fill ,not many of us like it or need that kind fill power But I gotta say I remember when I thought it was great too,about 30 yrs ago,until everyone started having problems with it.
Anyways,if you have epoxied it then done your filler work you should epoxy it again before putting any other kind of primer on ,thats how the pros do it for the best results.and use a wax& grease remover every time you get ready to spray anything...Back when we used it we started blocking it with 80grit because it sanded so hard,I dont know what they start blocking it with these days...That would be a big help for you to know too.
I'm assuming your doing a whole car,doing one or two panels is a little different..
Well, I'm asking now! What is the best primer and/or product/method to use for filling(?)/smoothing(?) relatively minor panel "ripples"(?)/"waves"(?) once the "dents" and "dings" have been filled and feathered? I have already overcoated with SPI Epoxy Primer.From what I had read using the SEARCH function and the Evercoat website, I thought that FEATHER FILL was to way to go, but appears I may have been wrong.
any primer that I would use or suggest would only be my personal opinion.what you should do is start a new thread and ask that question.This way you'll get everyones opinion of their experiances with different brands.I use two brands of urathane primer for production work and only one for super straight high quality work...SPI has about the best urathane high build primer Ive used so far ,it sands easy and it shrinkage is minimal ,its great for blocking a whole car down and gettting everything super straight...It is a little to thick for my production work though because for that I use a poly putty (evercoat) in place of primer for blocking ,its cheaper and faster for me ,when I prime its sanded with 320 -400 so I need a thinner primer not for straightening but filling any small scratches and something for the paint to stick to...
you havent mentioned anything about filling your dents just featheredging them.something that would help you imencely would be to guide coat "Everything" at "Every" stage of the operation,it'll be a lot faster and easier and take a lot of the guess work and mystery out of this. for instance guide coat your first coat of eopxy to find your high and low spots work the metal the best you can (this part is what really seperates the old timers from the newbies) on the bigger dents and waves use bondo (I like evercoats z grip) on your smaller stuff that doesnt need much filling use a poly putty (like evercoats ez sand).sand with 80..Guide coat your bondo and putty....re prime when done with more epoxy (Spi is great stuff) guide coat the epoxy and block again (180)(I like the black epoxy with a white guide coat) depending on everything you did so far and the kind of shape the car was in determines what kind of primer comes next...if you have any epoxy left use it all up,Spi can be use as a fill primer and you dont want to waste it by leaving it unused.many times you wont need any other primer but if its not straight enough use the urathane high build primer,guide coat and keep blocking with 180 ...this should get you in the ballpark for wet (block) sanding 320-400 ...You cant go wrong with SPI primers ,they're not super expensive and are of the highest quality and they have a tel,# you can call to get instant answears to any questions that can arise...You can use lower quality,cheaper materials and still get good results but this is a lot of work and no pro would take a chance on them.plus using cheaper, low end materials might even mean extra work...its just not worth it..But start a new thread and see what everyone else says they like ,weigh the pros and cons and make an informed decision based our knowlage and your budget..None of us know everything and whats right for me might not be right for you...
My mistake...That makes a lot more sense...You wouldnt believe the things I've seen people do with this product,filling dents is just one of them...
It hasnt been mentioned but when it first came out we had a lot of come backs because we wet sanded it and it absorbed water ..but,it might not be an issue any more with the new formula...
Tom, it's pretty hard to tell you what you need without being there to touch it and see exactly what you have.
Polyester primer is for SUPER high filling (primer wise) it IS like spraying "bondo". You could literally, I mean LITERALLY tape a dime on the fender and bury it with four or five coats of some polyester primers.
Polyester primer is great for something like a tailgate or firewall where you have a bunch of body lines and it is covered in dents or imperfections. You work out the plastic filler ("Bondo") with course paper (40 or 80) using much less time than finer paper and you don't don't have to apply a polyester putty or something to fill pin holes and those large scratches. You spray a few coats of poly primer on it and it is MUCH easier to work with than the body filler or poly putty.
It's great for bodies or parts that will need a skim coat of filler over the entire thing, you just can't replace polyester primer for stuff like that.
But for "regular" body work where your filler work is nice and finished off in 180 as it should be poly primer is a serous overkill. It's MUCH harder to sand, much harder to feather, it is just harder work with.
So feathering out paint around filler work if done properly, urethane primer is PLENTY and is done every single day in high quality shops all over the world.
Poly primer is a KILLER workhorse. I have done tests where I abused it big time, applying it over 36 grit scratches and painted black right over the top after preparing it with the proper finer grits and found ZERO shrinkage months later. The stuff is a killer workhorse. But it is not needed with most body and paint work.
It is a choice, an option and not horribly wrong or anything like that.
You know the NCP 280 primer is a self leveling primer right?
Builds mostly where needed while it's still wet and moving.
Hard to explain, kinda like explaing gravity .. But it's nice to have gravity on your side...
lots of TOP NOTCH restoration shops use poly primer. If you're saying I'm wrong, you're sayin bj's , gearhead, capital auto, redstar(custom), lugos, etc...is wrong.
I say you're right about PRODUCTION but you're speaking as if it's for techs that can't nothing straight. We hold car shows this summer and you're close....bring your best work and let's compare!
most classic cars greatly benefit from poly primer. I've busted my arse enough on them to know.
Were exactly did I say you were wrong? Never did I say you were wrong. As for "Production shops" who can't get anything straight, honestly that is where the bodyman has to get it straighter in most places I have worked. The paint shop hasn't the time to be repairing the bodyman's work. You get it near flawless leaving the filler in 180 with zero pin holes. The paint shop applies a couple of coats of urethane primer and blocks it to perfection. In most restoration shops the painter and his prep work is where this step is accomplished. He painstakingly primes and blocks it to perfection, sometimes with multiple applications of primer and blocking. And of course for a REAL show car or restoration the level of perfection is higher in how straight it needs to be as well. But it's the painter who usually puts it there with blocking primer. In the production shop the bodyman has to get it to VERY close so the paint shop need only apply one application of primer and a quick block to get it "production shop" quality. Often this is very very good, on a one year old $60K car you bet your butt it has to be pretty good. And they do this with one application of a few coats of primer over 180 sanded filler work with zero pin holes.
But it is much easier for a number of reasons, the rest of the panel is perfect because it has only the one dent being fixed in a near new panel, the paint is very thin being it has never been repainted so it's easier to feather out are a few of the reasons.
But honestly, I never said you were wrong. It is a good choice when doing a restoration and you have filler all over the panel and you have had to sculpt out body lines and such, it's a great choice. We have a 67 Chevelle for the boss at work right now that will probably get polyester primer over the entire thing. As my last line said... "It is a choice, an option and not horribly wrong or anything like that."
Any tech that's good at restoration can fix an isolated dent in production. It's a cake walk and most times they replace the part that's why so many production techs stumble when they get a classic car...they're overwhelmed.
As far as classics go, I like doing my own blocking. They can take the credit in the end.
btw, no you didn't say I was wrong. I had some beers last night. My perception was off but it sounded like you were saying it's unusual even for classic cars when it's quite common.
I honestly don't see how restoration work and production work is really any different, but you are absolutely right, your average collision guy couldn't do a nice restoration to save his life.
I came from the restoration side over to the collision side so I guess I see things different. I have always looked at collision repair AS restoration work. I mean, come on, if you are repairing a crunched 2009 Chevy Equinox aren't you "restoring" it back to original? What is the difference between that and "restoring" a 65 Mustang back to original? Obviously they are vastly different in the process, but the CONCEPT is exactly the same. I personally don't see the difference but many collision shop guys don't get it, you are right there.
As far as getting body work straight, you would be very surprised at how straight the guys where I work get their body work. The paint dept runs the show in this regard, you had better have the bodywork done good enough to finish it off in ONE two coat application of primer or you are getting it back to make it good enough.
I'm with you on doing your own blocking and paint prep work. I did it all for years so I am used to it, and honestly, I LOVE that final work. Bringing the work to paint perfect to me is a jazz, I love it. There is no guessing, there is no faking it, it is either right or wrong.
I wouldn't be surprised by how straight they get their work cause I can get it just as straight. For most dents it takes me two apps of filler so if a guy puts two coats of 2k and that's it the difference is just one more app of skim coat.
I think production guys get overwhelmed cause they aren't accustomed to waves in the metal, shear amount of dents, and hood/decklid supports. Just stuff you don't see in production. With that said, I'm sure they have all the tear down techniques you can dream of and weld good on paper thin metal.
btw, the shop I work at is a small restoration shop but we do work from all around the country. Anyhow, everyday I drive by this huge production shop that's known and they park their restorations outside and you can always see that very slight wavy ness. Having a solid process that's efficient isn't easy for production shops. I've been banging my head over it getting mine down and it didn't happen overnight. This process also means every hand on it must have the same pride and skill as you otherwise one mistake will hurt the process. You know all of this though. I'm just saying, I've seen the best production techs lay turds in restoration, and probably the same can be said about vice versa.
looks like I might be joining the dark side(production). Can't beat em join em, eh?
no money in restoration unless you're the owner or work at the best.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
