need some advice on T-350 and torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2010, 07:41 AM
hey everyone i need some advice about picking a transmission and torque converter.
Engine is a Small block chevy 400(bored out .040) with 9.3 compression lunati voodoo cam duration at 050 is (Int/Exh): 213/219
Gross Valve Lift (Int/Exh): .454/.468 LSA/ICL: 112/108 it also has an edelbrock 750 carb.
Estimated hp is around 410 horse and 525 Lbs. Ft. of torque.
This engine is in a truck 78 gmc jimmy with 4WD used for daily driving, some towing camping trailer 7000 and boat 2500, off road a little. Im not sure how to pick a torque converter for my application so any advice would be great!
Also i want to buy a new transmission i dont know how ot rebuild one so im just going to buy, i was looking at a TH350 monster transmission at eat my shift.com but i dont know if they have good reviews or not so any advice here would be good too!
Thanks for reading,
Mike
Old 03-02-2010, 08:21 AM
delawarebill's Avatar
tranny
me personally i'd use a th400.. but the th350 will work.. as for a converter... just use a stock one. that would be around 1500rpm unit. u don't need one in the 2000+ for normal use.
Old 03-02-2010, 08:50 AM
sqzbox's Avatar
My pipes are my music
If I were you, I would look into a shift improver kit. With the towing you do, a high stall converter is going to build a lot of heat and will need a GOOD cooling system to keep temperatures down.
Your also looking at a lot of work! I'd rather pull 2 engines than have to pull a tranny with the transfer case. The transfer weighs a ton and in my opinion, is a pain in the butt.
Unless you have the money to get someone else to do the work (which is the easiest way).
Old 03-02-2010, 11:50 AM
its good that you said to use a stock converter because it turns out that i called lunati and they said my cam can be used with a stock torque converter.
The reason im wanting to change trannys is becaue the one in it is a stock th350, and the engine is making more power than stock and the fluid is still red but with some black in it. i think the more power from the engine is burning stuff up in there. i dont know the diffrence between the th350 and th400, is the th400 better? and if it is, how much do i ahve to change to install that rather than the th350
Also the tranny is cooled by a 4 core radiator and i also added an aftermarket trans cooler that sits in front of the radiator.
Old 03-02-2010, 01:27 PM
It aint that bad sqz...I use a tranny jack an strap the transmission tight to the jack....in and out no sweat...change one in just a few hours. The 350 will be fine. To go to a 400 you'd have to get a transfer case with the right input and the right adapter but I think there are holes in the frame for either the 350 or 400 crossmember location but it ain't hard to fix that.
Old 03-02-2010, 11:37 PM
sqzbox's Avatar
Maybe it's the age thing I was a week from swapping out the tranny and transfer when I found the gov. was bad in my TH350. I was having some pressure problems in third gear. It would just go into neutral like mode while cruising down the road in third. I was stumped as to what the problem was. Someone on this site mentioned the gov. along with the modulator, and a host of other idea's.
For that, I'm forever grateful as I still have the rebuilt tranny siting on the floor collecting dust! I was planing to try the engine hoist through the passenger door thing through the hump on the floor. I remember lifting it out of the truck when I bought it and it seemed to have a close balance with a strap around the tranny tail and the transfer.
Old 03-04-2010, 04:37 AM
Thanks for reading,
Mike
I just rebuilt a th350 with the B&M 30229 kit and a Ron Sessions book. And I hated every step of it. Now let me say in fairness I hate fluid anything. If the thing starts with the word hyd I hates it. That all being said I can say in all honesty a well built DIY th350 is more than up to it and uses less of the power your looking to make than a t400
Turbo 350 Torque Converter jayd_2 Transmission - Rearend 1 10-29-2012 10:07 PM
need a torque converter need advice 64r1 Transmission - Rearend 8 06-11-2010 08:33 PM
can i t-350 torque converter be cleaned? new_rat_rodder Transmission - Rearend 5 03-16-2009 04:06 AM
Which Torque Converter for TH 350? Houman SS '70 Transmission - Rearend 2 07-13-2005 03:09 AM
advice on torque converter darom Transmission - Rearend 7 03-26-2003 06:44 AM
