Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need some advice on th350 and torque converter
Old 03-02-2010, 08:50 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
If I were you, I would look into a shift improver kit. With the towing you do, a high stall converter is going to build a lot of heat and will need a GOOD cooling system to keep temperatures down.
Your also looking at a lot of work! I'd rather pull 2 engines than have to pull a tranny with the transfer case. The transfer weighs a ton and in my opinion, is a pain in the butt.
Unless you have the money to get someone else to do the work (which is the easiest way).
