Need some advise on ABS plastic repairs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2006, 08:25 AM
Need some advise on ABS plastic repairs. I have a panel on a camper that has a large hole and some cracks from and accident. Need advise on how to repair damage areas. Some damage holes are in a curved part of the panel. Also suggestion on what type of paint to use. ANy help would be appreciated.
Old 11-01-2006, 08:56 PM
ABS is one of the easiest to work with, it welds OK and polyester fillers stick really well. Regular automotive paints work just fine with no need for any adhesion promoters. Be carefull with 1K paints though, lacquers and basecoats will sometimes melt abs if a good primer/sealer isn't used. Epoxy primer is your best bet and makes for an excellent solvent barrier.
Help painting ABS plastic. TurboS10 Body - Exterior 10 08-27-2012 10:30 PM
Working with ABS Plastic Kallie49 Interior 5 06-28-2006 09:45 PM
How to repair ABS plastic JSD Performance Body - Exterior 1 12-11-2005 06:11 PM
Plastic restoration lumberjacknooj Interior 8 11-23-2005 11:21 PM
Repair ABS Plastic Woody1 Body - Exterior 2 01-27-2004 07:53 AM
