Need some carb info - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2011, 10:53 AM
Need some carb info
I have this 85 ford f250 2wd and it has a 300 6 in it. I am having trouble figuring out what to do with my carb. rebuild it or go with a different carb.The carb I have right know is a carter 1bl eec iv feedback carb. We cant get in to run right.
Thanks
Old 11-06-2011, 12:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Can't get it to run right...what's it doing? Maybe it only needs a rebuild.
Semper Fi
Old 11-06-2011, 05:00 PM
The idle is ruff and it goes to about where it dies then it jumps back up
Old 11-06-2011, 05:35 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Feedback carbs ... ugh.
Nobody liked them (nor the infamous "VV" - variable venturi)
EFI couldn't come quick enough!
I can tell you that those 300's used the same carb for years and years, and that they were generally very dependable. 1975-1986 here in Canada at least according to the buyer's guide at Autoline Carbs Part # C6077
Parts info for my carb RobbieH Engine 1 09-08-2011 06:55 PM
carb info ballheadedfreak Engine 1 11-08-2008 01:40 PM
No info at all on predator carb? chevelle4542speed Engine 1 05-29-2006 09:07 PM
carb info? 68bird Engine 2 06-05-2003 06:48 PM
looking for some carb info Blag Hotrodders' Lounge 1 02-16-2003 02:12 PM
