need some flywheel help
i built a chevy motor and i got the fly wheel on and when i bolt the starter up i got a finger gap between fly wheel and starting gear
fly wheel
is there a difference in fly wheels on a chevy 350 and a 400 small block
Yes....the balance, 400 is externally balanced
Ontario Rodders |
Wrong starter...The starter you have is for the larger flywheel
Ontario Rodders |
fly wheell
thanks i put the fly wheel on and bolted the starter up and i had a finger gap between both gears.. but i took the fly wheel of his 350 but i looked up my vin on block and found out its a 400 wat kind of fly wheel does a 400 use.... first time building a motor
You need a 400 externally balanced flywheel....The starter you have will work with that
Ontario Rodders |
Cole
fly wheel
thanks alot for the help
Please read the board guidelines about double posting. Your second post has been merged into one.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
| gm flywheel | stans56 | Transmission - Rearend | 4 | 08-26-2010 07:46 PM |
| FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel | boneyard Buick | Transmission - Rearend | 1 | 07-20-2009 09:43 AM |
| 1-piece sbc flywheel vs LT1 flywheel | curtis73 | Engine | 2 | 12-02-2007 05:02 PM |
| FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? | boneyard Buick | Engine | 0 | 11-17-2006 07:20 PM |
| 454 Flywheel | Jim Vines | Engine | 3 | 07-18-2005 09:59 PM |
