-   -   need some friendly advice, fuel pump fuse problem (http://www.hotrodders.com/forum/need-some-friendly-advice-fuel-pump-fuse-problem-188934.html)
untchable502 12-10-2010 07:39 PM
i have a 2001 ford windstar that has been idling off and on kinda weird.... well here in the last 2 weeks it has been starting to blow fuses that are to the fuel pump..... are these 2 things symptoms of the fuel pump going bad or is it a different issue.... any advice would be great dont really want to drop 160 on a fuel pump if thats not the issue... thanks in advance
T-bucket23 12-10-2010 08:13 PM
Fuel pump or wiring to it. If you cant find anything in the wiring then I would change the pump
