need some friendly advice, fuel pump fuse problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2010, 07:39 PM
untchable502's Avatar
i have a 2001 ford windstar that has been idling off and on kinda weird.... well here in the last 2 weeks it has been starting to blow fuses that are to the fuel pump..... are these 2 things symptoms of the fuel pump going bad or is it a different issue.... any advice would be great dont really want to drop 160 on a fuel pump if thats not the issue... thanks in advance
Old 12-10-2010, 08:13 PM
T-bucket23's Avatar
Wiki Edits: 26
Fuel pump or wiring to it. If you cant find anything in the wiring then I would change the pump
Chet
fuel pressure problem - holley blue pump & reg stratt134 Engine 19 04-12-2013 02:44 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
excessive backfire and flames! also rocker arm knock chevykid90 Engine 53 08-27-2010 04:42 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
