Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some help with a 1965 Mustang cowl
Old 12-27-2010, 11:35 AM
KMatch KMatch is offline
Removing the cowl is as bad as it looks so I doubt you'll get any help in making it easier. However... I've seen some where the cowl vents were removed for repair access then the vents replaced with solid metal. It looks good and allows limited access. Otherwise I can only suggest cutting it as close to the windshield as your welding skills allow, but that sounds hokey to me.
