Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some help with 1986 GM 305, TBI or Carbed???
Old 12-19-2010, 07:32 AM
not2old4speed not2old4speed is offline
The carb. he is talking about has to be replaced with the same type, I think it is a 4EME4,on the right side of the carb.there is a plug(white) with 4wires, this is the throttle position sensor,it sends a siginal to the computer,which in turn controls the timing,the computer then sends a signal back to the carb,in the front of the carb,there is a blue cap that has 2 wires,this in turn controls the air/fuel mixture and the EGR valve.The 4EME4 is a 750cfm,if he uses any carb other than the one that is on it, he will have to replace the dist. as well.Having gone through this, I can tell you it is cheaper to replace the carb with the type that he has on it now.
