Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some help!
Thread: Need some help!
Old 10-22-2005, 05:36 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
If you are sure it's wired correctly, take the compressor back.......bad motor.
You should also check the pressure regulator, maybe it's not letting it kick in as it thinks the pressure is up.
