Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some help!
Thread: Need some help!
Old 10-22-2005, 08:13 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
My thinking is the green wire should go to a grounding bar in the switch box, they usually have bare wires and the white neutrals from the 110 circuits in them as well as the ground for the 220 (Green) If you have a double breaker 220 then you did right with the back and the white going to it.
