Need some help about my 1967 chevy truck frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2006, 02:48 AM
67Chevy_c10's Avatar
I'm restoreing a 1967 chevy truck frame and i have already used a wire wheel on the outside of my frame and i have that already down to bare steel,i used 80 grit sandpaper to sand the inside of the frame and i cant sand in the hard to reach places on the inside of the frame,i see rust in there and i was wondering what should i use to get rid of it? Is there anything out of eastwood that i could use? Thanks
Old 03-16-2006, 03:04 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
On a frame like that I would then sandblast the little hard to get places..What you are doing is fine and doing that way saves a lot of sand and money..That can be done with a small spot blaster..
Sam
Old 03-16-2006, 05:57 AM
budthespud's Avatar
Diehard Chevy Guy
Sam's Right
Ya got to sandblast the spots you can't get at. If you look in my project journal I'm working on a 66 Chev truck and I'm modifying the frame for air bags, boxing the frame for strength and a couple of new cross members for the overdrive trans I'm going to install. If you are going to this much trouble to get rid of the rust get a small sandblaster, you'll be glad you did!!
Old 03-16-2006, 11:23 PM
Thanks guys for helping me out
Old 03-17-2006, 05:56 PM
Does anyone know what kind of mask i can use for sandblasting? Where do i get one of these masks at? I have a 33 gal craftsman aircompresser with 150 psi..Can I use the sand out of a bucket and hook up my sandblasting gun to my 33 gal air compresser and use it? Dont mean to ask so many questions but i never sandblasted before so this is my first time.
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Chevy S-10 frame strength/to a 350 cu.in. 55 chevy rebuild Engine 1 02-11-2006 08:56 PM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 07:49 PM
66 chevy truck frame swapping ezoo Suspension - Brakes - Steering 9 01-13-2003 04:58 AM
1950 chevy frame swap trott Hotrodders' Lounge 2 12-23-2002 09:26 AM
