help with weatherproofing rockers!!!
Hey guys, over the past few months I have ripped out the floors and all braces and made some new full inner rockers, as well as purchased all pans and braces. I have weld through primer and was planning on using it on all pinch seams but my question was what should I do with the inner and outer rocker assembly as far as weatherproofing/sealing? I thought it might be ok if I taped off all pinch weld areas being primed with weld through and use some kind of a bed liner or possibly lizard skin. What did some of you do with your rides? Its a 62 impala 4 dr. and its gonna be a driver. Also when it comes to painting the under carriage, what were some of the steps you guys used? The car will be on the ground during most of the floor rebuild untill everyting is spotted in and than I plan on removing the body to finish up welding anything else and finally sealing/paint. Sorry so long but the more I try to figure it out on my own the more I will probably regret it. Thanks for looking.
Kevin
Kevin
