need some help from engine pros!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2003, 01:15 PM
Ebbsvette's Avatar
ok..i just installed a new cam into my 350...ok.......i had to get a new timing belt so i went with a double roller set up......now its all on and the cam gear dial is set at 6 oclock and the crank gear is set at 4degree advance and set at 12 oclock......now how to i set its timing and do the valve lash? im not real sure on the next steps in this process....if anyone knows what the proceedure is id sure like some help...thank you
