Need some help guys! stumped on timing chain!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 12:51 PM
hey guys,
ok Im stumped here. i just finished my 454 full solid roller alum heads had it running about 4 hours on it and the timing chain broke! :/ .. really weird i know, i have been doing research trying to figure out what the heck happened. this will sound crazy but my block number says its a gen 5 (91-95) ok everything on the motor matches a gen 5 however the front of the motor is drilled for a gen 6 timing cover. if you look at summits parts they give you a application for each part. the timing chain set i have was for a gen 5 i did not relize it was drilled for a gen 6 until last part of assembly when my timing cover was different. and they say the timing set is different for a gen 6. i cannot see how when comparing them but im wondering if thats what caused it to break. i was running a cam button with a very exspensive timing that broke in half when the timing chain decided to break. Do any of you guys have exp. with theses newer blocks. please share whatever you can. the motor ran awesome and had unbelievable power no signs anything was wrong until bang. no more chain.
thanks guys
Old 05-21-2012, 05:48 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What was you cam button clearance?
Semper Fi
Old 05-21-2012, 06:11 PM
Richiehd's Avatar
JS-70
Can you still turn the cam?
Years ago I did a timing chain for a customer, v8 Buick, same thing, it was running then quit, for no reason broke the chain. Put new set in, no problem. Not sure about your big block though
Old 05-21-2012, 07:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 1fast62
hey guys,
thanks guys
Could be a manufacturing defect. It could be something fell down between the gear and chain (small nut, bolt, screw, whatever) and that could snap it- after all, in a case like that something has got to give, and the chain is the weakest link.
I would carefully inspect the chain and gears under magnification for any signs of the cause, but unless you're a skilled inspector you may never know the exact cause.
Did the assembly go normally, the chain wasn't excessively tight or loose on installation?
You started to say an expensive "timing something" broke- was it the timing cover? If the end play was set incorrectly and the timing cover broke because of that, and a piece of the broken cover fell between the gear and chain... or the cam walked out far enough that the chain tried to ride up over the gear... that could account for it.
In other words, the cover broke first, causing the chain to break, not the chain breaking broke the timing cover.
Old 05-21-2012, 07:54 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
common lately
lately i've seen the cam alignment pins on the front of the cams fall out into the chain and break it. to solve this we've been grinding the pin down flush with the gear and putting the cam button tab over the pin so it cant fall out.
another thing could be crap gets in thwe pump and stops it. everything else is still spinning and breaks the chain.
this has stumped the best;327; cannot get timing right, pings under load, need help! hotrodcommuter Engine 10 12-18-2010 06:40 PM
I'm stumped, no timing mark Jmark Engine 10 04-16-2007 10:11 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
