Need some help with my front springs
I have some concerns with the new springs I installed in the front of my 68 Impala. I rebuilt the entire front end and when I installed the front springs I thought something was wrong when I had to compress them to get them in. The only springs I could find were for a small block and even after installing a big block with a 671 blower the front end didn't even move. Even with my brother and I standing on the front end (400lbs) it still didn't move without jumping. The upper control arm won't come off the rubber stop. Now I don't have the doors on or the glass in yet but I don't think that's going to help. I don't have the old springs to compare with. Any help would be great.
Thanks |
what is the part number of the springs?
also, a big block with aluminum heads is the same as a small block with cast iron heads. let me ask you this. how is the car sitting now with the doors off? is the ride height where you want it? some springs are stiff and wear in over time so if it sits where you like it run em and try not to overthink it. |
Sorry for the delay, out of town and I had to find my receipts. The part number on the springs (MOO 6084). I have cast heads on my big block. I'm about 2-3" above the ride height right now. The upper control arm is out of down travel. If I set the car on the ground there is absolutely no compression or travel in the front suspension.
Yep, I had so much trouble getting them in I thought the same thing that they weren't seating. Everything looked correct to fit, the ID and OD. What worried me was the length and the wire size. It was a major job just to compress them enough to get them in. I've changed springs in several late 60's and 70's Chevy's and I don't remember ever using a spring compressor. Maybe I'm just getting old.
You may be right. Ive found two springs for a 68 Impala, the one I have with a rate of 377 and another with a smaller wire and a rate of 300. I would like to find original dimensions; ID, Wire, and Length.
By vehicle application, there are 5 different coil spring choices for a 1968 Impala. Here are the specs on the 277-1828: Attributes # Coil Spring Coils : 9.98 Coil Spring Free Height : 16.79" Coil Spring I.D. : 3.82" Coil Spring Load Height : 12" Coil Spring Type : Two Tangential Ends Design Load : 1805 Spring Rate : 377 Wire Diameter : .672" The part # for the springs with a spring rate of 300 is 277-3220. # Coil Spring Coils : 9.95 Coil Spring Free Height : 17.53" Coil Spring I.D. : 3.812" Coil Spring Load Height : 11.75" Coil Spring Type : Two Tangential Ends Design Load : 1717 Spring Rate : 300 Wire Diameter : .64" As you can see ... not a lot of differences in load (ride) heights, and weaker springs typically have LONGER free heights as they compress more to arrive at the similar "Load Height" I can get you the specs on the other 3 as well if you like. Edit: PS. I remember helping change front springs in a 1966 Canadian Pontiac (similar car). We popped the lower ball joint out and lowered the lower control arm to the floor to relax the spring and remove it. We had a 5/16" chain wrapped and bolted to contain it if it happened to get loose on us. To install was just the opposite. We stuck the spring in, and then jacked the lower arm up until we could thread the nut back onto the ball joint. It wasn't easy, and it seemed like the entire weight of the car was on that one spring. Yes, using a spring compressor would have made the job a whole lot easier! (But we were 16 or 17 ... ALWAYS did things the hard way! )
I understand the hard way, at that age we knew everything and was 10' tall and bullet proof
. Let me ask this, where should my suspension travel be? I'm sure the upper control arm is to be smashing down on the rubber stop. If the control arm was 2" off the stop I would be close to my ride height. 66GMC I'd like to see those other spring numbers if it's not to much trouble. I do know this, I'm not a victim of the wrong part in the correct box. They are Moog #6084. All dimensions match your descriptions.
No sweat ... here are the remaing 3 possibilites.
As I'm sure that you already realize, the factors that influence the catalog choices are: Engine size Body type With or without AC (But IMO the "design load" is the best indicator.) I know that you mentioned that you and your brother were 400 lbs, but I'm sure that passenger loading is approximated and included in the "design load". Also .. don't be too quick to dismiss the weight of doors, seats, carpets, glass, etc ... just try picking them all up at once! 277-1170 Attributes # Coil Spring Coils : 9.97 Coil Spring Free Height : 16.89" Coil Spring I.D. : 3.81" Coil Spring Load Height : 11.81" Coil Spring Type : Two Tangential Ends Design Load : 2052 Spring Rate : 404 Wire Diameter : .69" 277-3221 Attributes # Coil Spring Coils : 9.95 Coil Spring Free Height : 16.56" Coil Spring I.D. : 3.82" Coil Spring Load Height : 11.75" Coil Spring Type : Two Tangential Ends Design Load : 1724 Spring Rate : 359 Wire Diameter : .672" 277-1929 Attributes # Coil Spring Coils : 9.88 Coil Spring Free Height : 17.59" Coil Spring I.D. : 3.85" Coil Spring Load Height : 10.25" Coil Spring Type : Two Tangential Ends Design Load : 2209 Spring Rate : 337 Wire Diameter : .656" Last edited by 66GMC; 06-27-2012 at 07:47 PM. |
OK this is how I'll handle it. I'm going to get her fully dressed and put some miles on her and see if she comes down like both BigChevyFTW and jfmmck suggested and if not I will use 66GMC's data to choose which spring to use next pending how far she drops. To tell the truth I really don't want to change them
. Thanks to all.
Personally, I think I would go with heaviest available ones. A BBC with cast heads and a blower ... you don't want that 8-qt oil pan dragging on the pavement.
Very true, but she's sitting like an old school straight axle. If I could change the subject for minute would you know why I can't see my journal photos?
| front springs | scfalk | Suspension - Brakes - Steering | 3 | 05-03-2012 07:22 PM |
| what front springs | 33 plymouth 5 window | Suspension - Brakes - Steering | 0 | 02-20-2012 06:47 AM |
| 81 c10 front coil springs swap for s-10 springs | campracing | Suspension - Brakes - Steering | 3 | 10-05-2009 04:51 PM |
| Front springs | DoubleVision | Suspension - Brakes - Steering | 3 | 01-20-2008 01:37 PM |
| front springs | mitch 36 | Suspension - Brakes - Steering | 2 | 04-05-2006 11:31 AM |
