Need some help picking out a new Torque converter, TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2012, 02:27 PM
Hey everyone,
I'm looking for a good torque converter for my 58 Chevy PU. Its a hotrod street driven truck. I need to know what brands and lines are a good value. I plan on installing a temp controlled fan assisted trans cooler. Gas mileage is not an issue. I'm not sure whats in it now, but it will idle in gear at about 800, put it in neutral and it goes up to about 1300.
Its a 383 Chevy
TH 350
Single Plane intake
Predator Carb
Vortec Heads
XE 274 H cam with 1.6 roller rockers
Equal length fenderwell headers
3.08 gears with 25" tall tires
Thanks, Jordon
Old 05-13-2012, 07:00 AM
delawarebill's Avatar
converter
with everything u said.. except the cam, i need to look that one up.. but if it's mild to smooth idle u'd be fine with a 2400 stall. i'm running a TCI and no problems.. the more rad the cam this higher the stall, the lighter the veh the higher the stall..
454/th350 torque converter? rlb3 Transmission - Rearend 1 12-04-2011 12:51 AM
need some advice on T-350 and torque converter SBCfan04 Transmission - Rearend 6 03-04-2010 04:37 AM
Tranny or torque converter? (th350 slipping) Mr. Y Transmission - Rearend 7 05-30-2009 01:17 AM
B.O.P. Torque Converter/Chevy TH350 redlightning Transmission - Rearend 2 12-30-2007 10:26 AM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
