need some help super t-10 linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2013, 08:08 PM
douglashwy's Avatar
have the rght adapter but got the wrong linkage need help. 75 super t-10 in 1964 chevelle
Old 08-12-2013, 02:07 PM
The problem is the Super T10 is 32 splines. You can PROBABLY use the 32 spline Muncie linkage and with a little coaxing, it'll fit alright. You may have to shorten the reverse rod
The mounting plate is different also. 27 spline Muncies and T10s had 2 mounting locations on the tail; 32 splines only have ONE; you you need more offset in the plate. If you dont get anywhere with the super T10; try googling 32 spline Muncie
Old 08-12-2013, 03:25 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I will post a pic of my linkage when I get home.
Old 08-12-2013, 08:54 PM
douglashwy's Avatar
ive got two kits now and its starting to get really frustrating and expensive im about to buy another its the 373-3163 hurst has it as for a muncie for my 64 but am unsure
Old 08-12-2013, 10:00 PM
Here is my Borg Warner Super T-10 Transmission with a Hurst Competition Plus shifter. Several angles for your viewing pleasure.
ID:	76587   Click image for larger version
The Following User Says Thank You to Silver Surfer For This Useful Post:
douglashwy (08-12-2013)
Old 08-12-2013, 10:03 PM
And one more since I have exceeded the file size limit.
Name:	IMG_0432 - Copy.jpg
Old 08-12-2013, 10:12 PM
douglashwy's Avatar
can you give me the rod numbers 1-2 3-4 rev. also mounting bracket number
Old 08-12-2013, 10:19 PM
douglashwy's Avatar
looks like 373-3163 install kit
Old 08-12-2013, 10:48 PM
This transmission is in neutral.
Image courtesy of Silver Surfer©
EDIT: I updated the pic since the Reverse linkage was wrong the first edit.
Old 08-12-2013, 11:12 PM
Here is the mounting bracket
Hurst part number 1957773
http://www.summitracing.com/parts/huu-1957773
Old 08-12-2013, 11:21 PM
douglashwy's Avatar
ok that is the bracket i have now i need the rod numbers
Old 08-12-2013, 11:58 PM
Well this is the thanks I get for crawling under the truck with a flash light and a mirror for you, eh?
competition plus shifter #3216274 3306126
mounting bracket #1957773
reverse rod: 2146
1-2 rod 32832? or maybe 23823?
3-4 rod, can't find it
backup light switch #2480003
http://www.summitracing.com/parts/huu-2480003
douglashwy (08-13-2013)
Old 08-13-2013, 09:25 AM
douglashwy's Avatar
reverse rod: 2146
thank you i appreciate all your help
Linkage 58darlene Engine 0 07-31-2010 05:23 PM
Help Me get my Linkage right! TorkMonster400 Engine 2 08-24-2009 06:39 AM
Super rare Pontiac super duty found on auction... F&J Hotrodders' Lounge 40 11-17-2008 08:37 PM
Linkage campy Engine 3 01-12-2008 05:14 PM
Linkage. Good Frosty Engine 3 04-03-2006 07:13 PM
