Need some help on timing cover and cam button combo. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2009, 12:20 PM
Hello guys well I just keep running into all kinds of issues with my truck and just can't get a break. This is a SBC 350 2 piece rear main seal early style block and I am putting in a Lunati voodoo retrofit Hydraullic roller cam and I got one of jegs aluminum timing covers wich clears my double roller timing chain just fine. Well I stuck my cam bolt locking plate on along with my jegs ( same as the comp .795 button) steel roller cam button and my cover hits my cam button and it seems like I have around a 1/8 to 1/4 space. I don't have any way of having the timing cover machined cause of funds and don't want to go with the hassel. I want to use the steel roller cam button cause it is the best option. Is anyone running this type of setup or close to it with a steel roller button and is so what did you do? Is there any suggestions on what I can do. I called summit and they said I can grind the button down but it would be too much cause the c clip that holds it together would be gone at that point. I just don't know what to do now. The summit tech guys where no help and could not offer any advice.
Thanks guys
Eric
Old 07-25-2009, 12:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What about using a simple nylon button? The material's not just nylon- it has properties so it'll handle the heat and wear. Comp had them- prob still does. They can be easily modified to whatever size is required.
Old 07-25-2009, 02:06 PM
Well I just got done looking around for different cam buttons and I was able to come up with a shorter one from comp cams and will go from there. My dad has a drill press and hopefully will be able to get the proper clearance by grinding out some of the cover. I hope it works. It's crap you have to customize so much stuff nowadays to make it work.
Eric
Old 07-25-2009, 05:37 PM
ericnova72's Avatar
More for Less Racer
You could also just machine the non c-clipped end of the button, done it many a time and it is the correct end to modify because you will hit the c-clip with very little metal removal from the other end.
Old 07-25-2009, 07:01 PM
That was what my dad was thinking of doing at first but he had a good point that taking off from the back of the button would not make it sit flush with the locking plate and would let it move back and forth in different motions with the cam. He was thinking of making a shim for it but I did not want to have to get into much headache to make this work. So I got the shorter button wich will help and now all I will have to do is clearance the cover some. In the future I will just get a nylon type button but I don't know how long (miles wise ) they last but I know they can be grinded down to spec. I will have to post and say how things went. Hopefully by the end of the week I will be able to post a new vid of my cam swap. Thanks guys
Eric
Old 07-26-2009, 06:32 AM
The cam button on my gear drive just has a series of washers in the middle of it, to shorten it you just eremove a washer or two..
Old 07-26-2009, 09:09 AM
Well mine does to I didn't know you could take them apart like that. Do you just remove the c clip and take some off then? I could try that but still don't know if I will have enough clearance. I will do that if necessary as well on my new one coming in if needed. Also not to sound stupid but what did you use to get the c clip off with? Would needle nose pliers work.
Thanks
Eric
Old 07-27-2009, 10:47 AM
bentwings's Avatar
bentwings
Use a small snap ring pliers. Made just for this. Get them at Auto Zone or other parts store. Necessary tool.
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 04:28 PM
