need some info on heads and cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 11:07 AM
I have a 1986 pro street s10 411 gears going with auto trans got a 350 40 over need to know what is the best head and cam intake combo has flat top pistons like to stay about 10.5 to 11 comp and 2800 to 3200 converter has 29 15.50 15 rear tires
Old 06-17-2012, 11:50 AM
Banned
You can easily use a 200cc runner, 220cc if you really want to spin it. You really need to give more info to get better answers. Budget, current parts, goals.
Old 06-17-2012, 12:14 PM
looking for about 400 horse engine is all new but stock heads and cam money not a problem just going to be a street rod
Old 06-17-2012, 01:13 PM
Banned
If you only want 400hp then go with some 190-200cc runners, a chamber to give you 10:1 compression and a hydraulic roller cam with about 220/225ish duration and .525ish lift. Cam specs will vary a little depending on the rest of the combo.
Old 06-17-2012, 02:19 PM
also need a good 4 link kit whoever did the frame work used leaf springs and thats not doing to work for me has anyone ever used the procomp heads 64cc work for what i want like i said at least 400 hp tried to find a 400 block for a 406 but hard to find around here in oakhill wv havent did alot of gas engines im a diesel mechanic
Old 06-20-2012, 01:30 PM
vinniekq2's Avatar
cam/heads
lol,for 420 horse power use the GM hot hydrailic roller and modified vortec heads. Smooth idle and great throttle response.3400 pound car will go mid 12s all day
Old 06-20-2012, 05:11 PM
cool rockin daddy's Avatar
And you know he has a roller block, how?
need help with cam dynamics cam info ShadowMSC Engine 9 11-01-2011 12:40 AM
cam info adel383 Introduce Yourself 2 02-23-2011 03:36 PM
Need Cam Dynamics Cam Info sykora9280 Introduce Yourself 1 11-04-2010 05:19 PM
need cam info please. durand322 Engine 4 03-03-2010 11:10 AM
Need fast info on ZZ4 heads and cam TurboS10 Engine 2 11-23-2004 06:23 AM
