Need some kind of OEM temperature sender for my electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 07:52 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I want to put an electric fan in my mustang, and I'd like to get a little temperature switch that screws into my intake manifold and kicks the fan relay when the engine heats up. I'd like to get something thats cheap, like something off a production car that I can get from the parts store. Anyone know of a make/model of car that might have what I want? like maybe a 1991 camaro has it or something.
I'd like something like this http://store.summitracing.com/defaul...5&autoview=sku
Russel
Old 02-02-2006, 08:01 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What's wrong with using a stock Mustang Sender..?
Just run the sender wire to your relay coil ground..As the temp rises, the resistance at the sender declines provides ground to the fan relay, closes it, and the fan turns on.
Almost All fan relays control circuits are wired to ground, as senders are referenced to ground.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-02-2006, 08:04 PM
Wiki Edits: 2
Do I just ask for a sender for a late 90ies mustang? My stang came with a mechanical fan from the factory, and I don't really know too much about how factory senders and relays controlled the fans.
Do you think that a stock sender, operating as you describe, will turn the fan on and off at ideal temperatures?
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
Duel Electric Fan Questions..help needed sum87mustang Electrical 5 01-30-2004 12:49 PM
Duel Electric Fan Questions..help needed sum87mustang Engine 1 01-26-2004 10:25 PM
Electric fan opinions... VRTSid Engine 6 02-04-2003 01:35 PM
Electric fan? zachscc Engine 4 01-11-2003 08:32 PM
