Need Some Powder Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2006, 07:36 PM
cfatrat's Avatar
Anyone know of a good powder coat shop around Kentucky, Tennessee, Indiana? I need to get my subframe and parts done in a semi-gloss.
Old 01-25-2006, 07:54 PM
Chopt 48's Avatar
A Google search Provided this link. http://www.thomasnet.com/kentucky/po...2441357-1.html
Some of these may only service commercial accounts and some will do work for the public. Some may not have the capability to handle a frame.
Remember that you have to have all welding' fitting and grinding finished before powercoating. It is also a good idea to have it as clean as possible meaning, no grease or oil. Most power coaters will have a sandblast room or a connection with one.
Old 01-27-2006, 02:31 PM
GMW GMW is offline
If your interested in having it done in Evansville I can steer you.
Old 01-29-2006, 09:10 PM
cfatrat's Avatar
Yeah, I would be interested. Especially if they can do semi-gloss.
Old 01-30-2006, 01:32 AM
milo's Avatar
point on positive
Another experience has been the powder coating process that involves heat can warp some parts you might think would be a cake walk ...everyone likes to let on like powder coating is a point and click type solution when many times the results are less than expected..
lessons learned ...ask about the heat part...
Old 01-30-2006, 07:47 AM
GMW GMW is offline
The color and the gloss is a byproduct of the type of powder you use. It has nothing to do with the process. The process is pretty much always the same.
Clean the parts, sandblasting is a good way to do this or stripping. Pretty much anyway that's acceptable for liquid painting is acceptable for powder coating. You then apply the powder with a special "powder" gun and then bake for 20-30 minutes at 325-350 degrees F.
As milo said if your parts can't take 325-350 degrees F for 20-30 minutes then powder coating is not for those parts.
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
powdercoating madhat Body - Exterior 37 08-10-2004 06:00 PM
can you powder coat exaust? fire power Engine 4 01-05-2004 08:46 AM
Chicago electrics powder coat system daimon1054 Body - Exterior 3 11-26-2003 01:46 PM
