Need some question answered - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2004, 05:56 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
When you look at people talking about SBC's and look at the engine ads in magazines, it reads "350 SBC, 4 bolt main".
What does the "4-bolt mean"? Is that the engine mount related?
Mike
Old 07-02-2004, 06:35 PM
Wiki Edits: 49
4 bolt refers to the number of bolts on each crankshaft main cap. 4 bolt caps add strength to the bottom end of the motor so it can safely rev to a higher rpm than an equivalent 2 bolt main motor.
Centerline
Old 07-03-2004, 04:31 AM
Tazz
SBC 4 bolt main
Most people get by with the 2 bolt main engines just fine. For the few who want big HP from their 350sbc the 4 bolt main is the way to go.
Tazz
Rat Rods Rule!
Old 07-03-2004, 07:01 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Thanks a lot, so for a first time rebuilder I woulnt necesarly need a 4 bolt main but it would be better right?
Mike
Old 07-03-2004, 07:51 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
I don't think it would necessarily be better to have a 4 bolt main. Even though there are 4 bolts on each main cap, the caps that are used in the 2 bolt system are alot thicker than the 4 bolt one and some would argue they are better for a high torque motor.
Sorry I couldn't be more specific, but a good example is my friend's stroked small block. Based off a 2 bolt main 350 out of a chevy half ton pickup, the mechanic that internally balanced it said it would be good for 7500RPM without any problems.
Old 07-03-2004, 10:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
There are about a gazillion and a half hottie 350 2-bolters out there that are doing fine. Build a 2-bolter and drive happy.
Old 07-04-2004, 05:30 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
I have read a few articles that said if the motor is going to see less than 650 horses the 2 bolt would be fine. More than that and go 4 bolt. On the pic below it shows 4 bolt mains. These are not stock but a conversion kit to make a 2 bolt into a 4 bolt but it gives you the basic idea.
Kevin
Old 07-04-2004, 05:52 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Cool, thanks Kevin and everyone else.
I'm looking at a 1978 350 that was running when it was pulled. Carb to engine all complete. $300. We'll see what happens.
Again thanks everyone,
Mike
