need some SBC advice/help!!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-02-2006, 04:36 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Well, I've heard some bad things about Advance engines too..
Did you re torque the heads after break in? You should do that, and do that on this rebuild..
You Should also get a recovery kit..this will keep the air OUT of the system and can cause hot Pockets, and poor circulation (air Bubbles) .. The Recovery will draw back coolant when it expels air, instead of more air.
Doc
  #17 (permalink)
Old 12-02-2006, 04:39 PM
funny how you remember all of the little stuff once the problem happens
  #18 (permalink)
Old 12-02-2006, 04:40 PM
wheres a good place to find a recovery kit?
  #19 (permalink)
Old 12-06-2006, 08:20 PM
ok, here's a little update. Got the engine reassembled as far as the heads and intake, everything torqued. Now my sticking point seems to be getting my distributer to go back in where it came out of. I marked it on there, as to re-align it, and I can't get it to drop back in. It will go in all except about 1/4 inch or so. I did not crank over the motor at all after it was pulled. Anybody have any hints? I must be missing something obvious.
  #20 (permalink)
Old 12-06-2006, 08:54 PM
The oil pump drive shaft probably turned a little bit on its own when you removed the distributor.......You can take a long reg screwdriver with distributor out and turn the oil pump driveshaft a little bit and try sticking the distributor back in.......
  #21 (permalink)
Old 12-07-2006, 05:36 PM
thanks, am currently weathering this "snowstorm" in northwestern PA, weather supposed to turn better on sunday and monday (working outside) will give that a whirl .
  #22 (permalink)
Old 12-09-2006, 05:27 AM
need some quick info. Me and a guy at work were arguing about this. I torqued my head bolts all to 65 ft. lbs. according to the haynes manual. Is that the right torque spec ? or is the book wrong? He thinks it should be more than that. I'm at a spot where I can torque them farther if I were to need too. I've got 5 or 6 inches of snow sitting on top of my truck , waiting on it to melt before I go any further putting it back together
  #23 (permalink)
Old 12-09-2006, 10:59 AM
really need to know if 65 ft lbs is enough torque for the head bolts. Am working on it now, and don't want to button up any farther until I'm certain its correct
thanks
  #24 (permalink)
Old 12-09-2006, 11:54 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Since my wife has cleaned out the computer room and relocated my chevy truck manual---had to look elsewhere.
My 58 chev manual gives lightly oiled bolts ---min-60 max 70
So at 65 you are good-----
70-75 should do no harm if ya wanna snug em up a bit more, or you are not sure about the accuracy of the wrench.
Bryan
  #25 (permalink)
Old 12-09-2006, 01:39 PM
thanks much, earlier I also called local napa store, and they told me the same thing so I think I'm good to go, the wrench was pretty new
  #26 (permalink)
Old 12-09-2006, 03:26 PM
thanks, fellas. Well, so far so good, today I got it most of the way back together, got the valve covers cleaned and re-installed, carb back on, headers on, and new spark plugs in. this morning I used the screwdriver in the dist. hole, small turn, fell right in on first try.
also got the water pump re-installed. then I ran out of daylight.
Tommorrow I'm hoping to get it finished and fired up. I'll post a final update to let you guys know if I got it.
thanks again
  #27 (permalink)
Old 12-10-2006, 12:52 PM
one more quick question, fellas. I got the whole thing back together, double checked everything, it all looks good to go. So, I refilled the radiator, and then I drained the oil for a fresh change. And, low and behold, I got the standard half gallon or so of antifreeze that drained out before the oil did. My question is that I was wondering if, after I change the oil and get 'er running again, should I change the oil and filter again soon, like within 40 or 50 miles? Would there still possibly be some leftover antifreeze in there hiding? Or should it be fine without the extra oil and filter change? thanks again
also, doc vette said earlier that I should re-torque the head bolts after a "break in" The fel-pro gasket set I used said that there was no re-torque necessary. I figure it wouldn't hurt to re-torque them anyways to be sure. what kind of breakin time should I give it before re-torquing?
  #28 (permalink)
Old 12-10-2006, 03:21 PM
ok fellas, more troubles I think. I'm ready to go buy a Honda well, not ever. lol
Anyways, its all done, changed oil, refilled antifreeze. Went to fire it up, got nothing, no gauges. I DO have headlights. I threw the jumper cables on it, and could still get nothing on gauges or anywhere inside, only headlights.
Well, I didn't think anything of it at the time, but during the "process" at one point the red lead from the back of the alternator shorted out as it was just hanging there. Do you guys think I cooked something in there somewhere? where would a likely place to start be? I tried to check all the connections at the distributer, they are all plugged in, battery cables are hooked up and tight, and I'm about 99.9 percent sure that its all hooked up, and tight.
thanks fellas
  #29 (permalink)
Old 12-10-2006, 03:23 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You blew out the main fuse link when you shorted the alternator.
Get and replace the link.
Doc
  #30 (permalink)
Old 12-10-2006, 03:28 PM
fusable link? where am I gonna find that at? any ideas or do you mean in the fuse box?
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
$4,557.99 for SBC 400 Parts/Machine Work DTL504 Engine 35 04-03-2006 05:36 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
