OK, so now I've got the thing tore down to the cylinder heads, all the bolts are out on both sides. Now I'm having a problem getting the darned things to dislodge from the block. I don't want to pry in between them obviously. Tried using a block of wood and a hammer. They don't want to budge. Anybody have any tricks to get 'em loose? also, when I get them off finally, what things should I check for? I want to make sure that the motor only needs head gaskets, and that there is no damage anywhere. Thanks in advance for any help, its greatly appriciated!!!!
