Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need some SBC advice/help!!!
Old 12-02-2006, 04:11 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
Try putting the plugs back in, and cranking it..Sometimes the compression will "Blow" them loose..
You WILL have to reset the Distributer when you reassemble it though..
If you have an Engine lift, you can Chain each head one at a time, and SLOWLY jack it up until they pop loose..If you start lifting the car, stop..something is still attached!
Doc
