Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need some SBC advice/help!!!
Old 12-02-2006, 04:13 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Originally Posted by ChevyJim
yes all 34 were out. I went out earlier and gave it a gentle nudge with a cloth wrapped breaker bar (handle end) and it popped loose, and low and behold, #7 cylynder full of antifreeze, and head gasket had a weird "v" shaped kink in it, inward. pretty sure that was the problem.
tommorrow I'll take it all over to the shop, and get everything cleaned up good, degreased, and repainted. I'll post when I get it back together, let you guys know if I got it or not.
thanks
Doc here,
Better get it surface Checked ... It may be warped! or you could be doing this again.
Doc
