Need some serious Help,gonna break something - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2007, 05:34 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I am working on my brothers 92 lincoln town car.We were having alot of problems the the alt./charging system.We figured it out.Then the battery was draining,found the draw and fixed it.the car was sitting for about a month while we got time to fix it.SO today i changed the oil,oil filter,plugs,air cleaner,and added some fuel injector cleaner.Well it started right up and we got it to the gas station and put some air in the tires and as we were leaving it was like stalling alittle,not transmission stalling like it almost was getting starved of fuel.then we got it to the next gas station and now it keeps dieing when put in gear,any gear,SO i had to keep the gas down a bit while putting it in gear or coming up to stop signs to stop it from dieing.I am going to check the fuel filter tommarow but its only about a year old.What else could be making it die like that?If it were an older car/non fuel injected with computers I could figure it out,just not that familiar with newer cars.Could it be some kind of sensor?
Old 01-10-2007, 05:37 PM
Bumpstick's Avatar
Hammer and a torch
IAC (Idle Air Control)... Up on top of the intake has a 2 wire plug and 2-10mm headed bolts that hold it in place... R&R it (go to the Ford dealer for the correct replacement)...
Old 01-10-2007, 06:22 PM
84 Monte Carlo's Avatar
Auto Tech
Last journal entry: super chevy show
you could just clean it,do it all the time with air intake cleaner(the iac).
Old 01-10-2007, 07:15 PM
Anyone have a diagram?I just looked and didnt see anything like that.
Old 01-10-2007, 07:50 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have had similar issues with both of my T-Birds (94-97)
Both of em needed the MASS airflow sensor replaced
(the 97 died in rush hour traffic--on the freeway)
Also----a sticky EGR valve could do the same thing (sticking open)
Bryan
Thinking back----MASS Sensor may have failed on both cars after charging issues with both
Alt diode with the 94
10yr old batt on the 97
Old 01-10-2007, 08:40 PM
Does anybody know exactly where its at on a 92 lincoln town car with a v8 4.6L?
Old 01-10-2007, 08:54 PM
it is mounted to the side of the throttle body should be by two bolts remove them clean the area put on new gasket tighten bolts 71 to 97 inch pounds
Old 01-11-2007, 03:30 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Does it run OK except it won't idle? If it is an idle problem only, then IAC is a good place to start.
Got a check engine light? Steady or blinking?
Old 01-11-2007, 06:00 PM
Auto Tech
just for info,A MAF(Mass air flow) sensor can also be cleaned and should allways be tested befor it 's replaced.
Old 01-11-2007, 07:42 PM
do you mean cleaning the heat element in the sensor
Old 01-11-2007, 07:57 PM
Auto Tech
there are two elements.one visable another in the tube.the one in the tube is to be cleaned.I spray into the tube with a little tube.NOT carb cleaner!AIR INTAKE CLEANER or motor vac chemical.also clean the visable one.it's really hard to diagnose through Email,so before changing parts I would have it check.I would clean the IAC frist. Also look for vacume leaks
Old 01-12-2007, 11:05 AM
Yeah the check engine light comes on like every ten minutes for about 5 mins then shuts off.It wont idle while in gear,it idles in park but doesnt sound as strong as it should
Old 01-12-2007, 03:08 PM
Alright i found the IAC and cleaned it,it was pretty nasty,I cleaned the MAS,I also cleaned that valve with the spungy thing in it.It doesnt die anymore but still runs like crap.When the engine is cold it doesnt do it.After it gets full warmed up it sputters when you accelerate from a dead stop,also while going a steady speed it does it.The fuel filter was kinda bad so i replaced it.What else could it be?It feels like its getting starved of gas at certain times.any help is appreciated
Old 01-12-2007, 03:20 PM
Just for good measure, you should also replace the fuel filter and either dump some HEET into the tank or siphon out the old gas and replace it. Sounds like you might have some water in the tank from sitting.
Old 01-12-2007, 03:24 PM
I replaced the fuel filter,and it was on empty when i fixed the electrical problem,just put a half a tank in yesterday and some fuel injector cleaner.It was only sitting for a month but started it every couple of days
After break in oil. DeathRattle Engine 7 12-23-2006 09:21 PM
Break lites don't work? 31 Ford A Electrical 13 08-23-2006 05:34 PM
Oil Weight Break In Again spanky36 Engine 2 06-18-2006 09:41 PM
Spring break is finally here, but....... onebadmerc Hotrodders' Lounge 3 03-18-2005 08:26 AM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 04:50 AM
