Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some trans and shifter ID help.
Old 05-11-2012, 05:59 AM
unclebuck20 unclebuck20 is offline
Trans Help
Check the serial numbers on the trans. If it was me i would pull the trans and go through it. Once you you identify the trans you can get the proper shifter for it. or grind a slot in the crossmember to clear the shifter rod.
