Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some trans and shifter ID help.
Old 05-13-2012, 08:21 PM
Gamecock66 Gamecock66 is offline
Originally Posted by joe_padavano
Trans is cast iron, revers is on the side cover (not the tailhousing) and the shifter mounts on a large bracket, not the normal one-piece plate. Everything points to a Saginaw.
Any idea what shifter I need or if there is anything I can do with this one to make it work? Right now it is offset so far to the left that I cannot fix the hole in the floor with the proper shifter hump and get the console to fit.
