Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need some trans and shifter ID help.
Old 05-18-2012, 04:00 PM
junior stocker's Avatar
junior stocker junior stocker is offline
It is a Hurst shift based on the mount bracket used. The "tower" assembly however could be meant for ant make car originally, and just adapted by using the correct rods. In my case, I used a Hurst shift originally from a MOPAR with the "pistol grip" design shifter handle. Your car also has a 55-59 Chevrolet TRUCK bellhousing based on the bolts/nuts on the lower trans ears. You could probably shorten the reverse lever on the shifter tower, and redrill the hole for the reverse rod, in order to gain some clearance. junior stocker.
