Need some trans and shifter ID help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2012, 08:24 PM
Ok guys this is in my 66 Chevelle. The PO swaped the auto to a four speed and I am trying to figure out what trans it is, If the cross member is correct or home made fabrication. I also want to show the issue with the shfter hitting the cross member with the reverse finger. I know it is not the correct shifter. I beleive it is for a Camaro. So here are the pics. The red lines and red box shows the reverse rod that hits the cross member. Any info is greatly appreciated!
Old 05-11-2012, 03:20 AM
Wiki Edits: 85
Bottom ribs suggest that it is a Saginaw to me, but cannot be sure with your pictures.
Old 05-11-2012, 05:59 AM
Trans Help
Check the serial numbers on the trans. If it was me i would pull the trans and go through it. Once you you identify the trans you can get the proper shifter for it. or grind a slot in the crossmember to clear the shifter rod.
Old 05-11-2012, 06:58 AM
I believe its a saginaw, but those pictures all have a weird angle to them. As said before, get a casting number from something on the trans.
Old 05-13-2012, 06:04 PM
Trans is cast iron, revers is on the side cover (not the tailhousing) and the shifter mounts on a large bracket, not the normal one-piece plate. Everything points to a Saginaw.
Old 05-13-2012, 07:21 PM
Any idea what shifter I need or if there is anything I can do with this one to make it work? Right now it is offset so far to the left that I cannot fix the hole in the floor with the proper shifter hump and get the console to fit.
Thanks
Wade
Old 05-15-2012, 07:53 PM
junior stocker's Avatar
You have a Saginaw 4-speed, and unfortunately, it's one of the lighter duty ones having come from a Vega/Monza application (based on the extension housing having the provision for the anti-vibration weight). Should be fine as long as you don't beat it. You probably did'nt want to hear that. junior stocker.
Old 05-16-2012, 06:48 AM
Thanks. Nah it is ok hearing it. I am building a BB for it and will bite the bullet when it comes time and get a muncie or opt for a 5speed. My main goal right now is to get this thing going as a driving project. I need to figure out what shifter to use in order to fix the floor and run my console.
If anyone knows what I need please let me know. If anyone has a used one that will work let me know that as well.
thanks
Wade
Old 05-18-2012, 03:00 PM
It is a Hurst shift based on the mount bracket used. The "tower" assembly however could be meant for ant make car originally, and just adapted by using the correct rods. In my case, I used a Hurst shift originally from a MOPAR with the "pistol grip" design shifter handle. Your car also has a 55-59 Chevrolet TRUCK bellhousing based on the bolts/nuts on the lower trans ears. You could probably shorten the reverse lever on the shifter tower, and redrill the hole for the reverse rod, in order to gain some clearance. junior stocker.
56 chev. auto trans. shifter db flyer Transmission - Rearend 1 10-23-2010 07:58 PM
Moving trans shifter my29 Hotrodding Basics 2 11-08-2009 12:23 PM
saginaw trans in 76 vette/what shifter to use steve007 Transmission - Rearend 2 03-15-2008 07:02 PM
Pro 5.0 Shifter for a GM T-56 trans - Anyone tried it?? hotrodf1 Transmission - Rearend 2 05-22-2006 07:18 AM
Shifter/Trans trouble VWFan Transmission - Rearend 6 10-21-2004 03:42 PM
