Good ol' McMaster-Carr and for about $21 including shipping for a 10 foot length
http://www.mcmaster.com/#hook-and-loop/=52aw1e That is if what I have in my shop isn't super adhesive (the Velcro is, that I'm sure) Dave W |
first off you need to use the industrial velcro, then prime with the adhesive promoter, let dry and stick it. we use a lot of 3m tape to hold plastic facias and body kits on new cars. it turns 50 mph tape into 100 mph tape. you will not pull it off. more info |
I think you are forgetting that the bond between the Velcro hook and the Velcro loop wouldn't be as strong as the Velcro attached to the door or whatever you are putting it on. In other words, while it is important to have the Velcro firmly attached to both pieces, the hook and loop is the weakest point because it is made to come apart.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Dan and all - while I am far from sold on the Velcro yet, I'm not sure that it isn't on a par with the 'Ford' clips. While the failed clips on my panels might be the result of many times on and off while doing the upholstery, all but one were bent and one of those bent broke a leg when I was pulling them out. Obviously I'll need some more if I go that way - but that's not a problem. Regardless, the doors will have the 'Ford' clips as will the kick panels.
I did finished 'experiment' that I said I would above with some very heavy duty self lock mushroom type "Velcro". While they are extremely strong pulling apart, there was very little shear strength and they came off with little effort even after 3-4 hours setup time. I don't have the 3M adhesion helper so the ABS might not have the ability to hold that tape without it being used - and today - not a chance on doing a run to look for some for a trial. I'll continue over the weekend most likely and get back here with some results. All - have a great Christmas Dave W |
3M has that clear hook and loop type stuff. it's velcro but made of plastic and both sides are the same. it's called 3M ' Dual Lock. and it holds strong.. uses that extra strength 3M contact tape for a backer.. it's expensive tho
http://www.shop3m.com/70070415982.ht...cking-Fastener |
There are a couple of problems with using Velcro to fasten panels. One is the cost. It is obviously a lot less costly to use $2 worth of clips than $50 worth of Velcro. Another is the thickness of the two pieces when put together, and the obvious problem of getting the Velcro attached, and keeping it attached. I can see where in some isolated cases Velcro might be a viable alternative, but I think the mechanical fasteners are much easier, less time consuming, and far less expensive. JMHO.
Good points Dan, but my panels had to be so thin that when I used any type of traditional fastener I had to laminate it between two pieces of material to prevent telegraphing through the upholstery that it made the door panels way too thick. I placed the Velcro around the panel about 2" inboard and a few pieces in the middle and it so far has worked out real well. I don't remember exactly what I paid for the commercial grade Velcro at Wally World, but all of it I bought was sure far less than $50.
Vince |
Take a look at this McMaster-Carr page. This stuff is ~.125 when the two pieces are mated, while others are .188 up to .250. There are differences depending on what you need/can use. While the stuff from Wally's - who knows, but it sound like you made it work for your '34, Vince.
http://www.mcmaster.com/#catalog/115/3397/=534nny Dave W |
I know we have discussed this in the past, Vince. One of my suppliers has what is called "super adhesive" Velcro which will withstand 300 degree heat. My cost on it 1" wide is
about $2.75 a yard per side, so one yard of hook and loop is $5.50. I used it on one of the local fire trucks to attach a cover to the metal truck body, and it worked great. It takes a full day for the adhesive to cure completely. I special ordered 2" wide stuff and it was a lot more expensive than that.
Dave & Dan here is a pic of male & female(for lack of a better term) fastened together. It is at best no more than .125" of an inch and is actually slightly less as the camera is at a bit of an angle and not straight down. Also both sides of the sticky still have the plastic on them.
Second photo is what I have left after purchasing two packages from Wally World. It is in the fabrics/crafts section and is available in black or white. Give this stuff a try Dave, if it doesn't work for you so be it, but you haven't't spent a bunch of money on it. Vince |
As far as saving money on this car I'm beyond redemption. My new Lokar $40 small oval brake pedal came Wednesday as the rectangular Gennie was within an eighth of an inch of the steering column, then there are the replacement $20 door check straps for those that I cut too short as well as the $5 cowl seal that was wrong, regardless of the label Then there's the cheapie HF pneumatic stapler I need to make some changes as my Craftsman electric one wont penetrate the ABS....and that's just this week.- now off to a pleasant family get together at my sister in law's house Dave W |
There, see how easy it is to save all that money?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
| Recent Interior posts with photos |
| Chassis plans etc | Jonesy_sa | Hotrodding Basics | 7 | 11-28-2008 06:10 PM |
| 50 Ford F1 w Monte Carlo Clip | joe123 | Suspension - Brakes - Steering | 5 | 05-26-2008 05:48 AM |
