Need Some Wiring Help Please - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-10-2011, 07:37 AM
Overdriv's Avatar
Originally Posted by chevyrestore
ok one of the wiring diagrams I found online a while back recommended that I add a diode to the 2 terminals on the fan. I happened to have the right diode laying around so I figured I would add it. See the link below for the wiring diagram a little over half way down.
http://www.fordmuscle.com/archives/2...cfan/index.php
I have the diode here and it has a color band on one side of it. Does the side with the band go on the negative or the positive side of the fan?
I think you would put the striped end toward the ground.
  #32 (permalink)
Old 05-10-2011, 08:40 AM
chevyrestore's Avatar
http://www.google.com/imgres?imgurl=...w=1280&bih=707
according to that wouldnt the stripe go on the positive side?
  #33 (permalink)
Old 05-10-2011, 05:47 PM
75gmck25's Avatar
With a diode the power flows from the end without the stripe to the end with the stripe.
Bruce
  #34 (permalink)
Old 05-10-2011, 06:31 PM
thanks Bruce, so do you agree that the striped side of the diode will go on the positive terminal of the fan as drawn in the above link schematic?
  #35 (permalink)
Old 05-10-2011, 11:32 PM
Joe G's Avatar
I agree that the banded end of the diode should be connected to the positive motor lead. That way while the fan is powered, the diode stops the current from passing directly through to the ground lead...which would be a short circuit. If you hooked the diode up the other way, with the banded end to the ground lead, the diode would fry instantly when the fan relay came on.
Good luck....
  #36 (permalink)
Old 05-10-2011, 11:46 PM
thanks Joe...I figured if the banded end was on the positive side then when the fan is shut off and still freewheeling then the generated electricity would bleed off to ground
you guys are always the best
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 06:42 PM
HEI Wiring Please help 64novaboy Electrical 3 10-16-2004 03:49 PM
wiring kit '67 barracuda Electrical 1 03-07-2004 04:14 PM
Wiring Stutch Electrical 12 06-23-2003 07:09 AM
wiring have a go murraydavidson Electrical 4 05-29-2003 09:20 AM
