need someone to calculate compression ratio please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 02:29 AM
Can someone please tell me what the compression ratio is for a 454 chevy with a 4.280 bore x 4.00 stroke, with a 2 valve relief piston with a .090 dish, .024 below deck surface, 118cc heads, and a .039 head gasket please.
Old 03-19-2012, 04:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Need to know the volume of the piston dish. Might find it by the part number if you don't know it, or by googling it. You can get semi-close by measuring the diameter of the dish and figuring the volume by using the formula for the volume of a cylinder: pi x r2 x h .
Then plug all your numbers into a calculator like this one. Pay attention to the signs of your numbers as explained on the calculator site; different calculators vary on what sign represents a dished piston volume, for instance.
Old 03-19-2012, 11:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Very low- like not even 7.5:1 w/a dish of 13cc or bigger...
Old 03-19-2012, 12:47 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
With all that info, and assuming 8cc for the piston (7cc for valve reliefs and 1cc for the dish), that comes out to: 7.69 : 1
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Calculate Compression Ratio for blown SB CHEVY? physcult Engine 40 08-15-2010 08:05 PM
Calculate final drive ratio 1930u Transmission - Rearend 3 09-30-2007 02:35 PM
Calculate compression lost using high performance camshaft? newchevyman Engine 25 01-28-2004 07:39 PM
Compression Ratio BlownBirdy Engine 3 12-18-2003 08:46 PM
