Need Specs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 01:10 PM
Idriveatincan's Avatar
1955 Fam Sedan
Last journal entry: I FOUND IT!!
Need Specs?
I was surfing around the web and found this site- They're pretty accurate with their specs. They don't contain everything though. Check them out- they were able to help me a bit.
http://www.edge-inc.net/cars/
Old 10-18-2005, 02:00 PM
I checked my old cars and they were WAY off......
but thanks for the site....it may help others......
Old 10-18-2005, 11:26 PM
powerrodsmike's Avatar
Wiki Edits: 161
That site is pretty cool. It said a 1934 ford 3 window would do 127 mph top speed and had 330 HP. And it only took 13.8 mpg to do it. Musta been a prototype. Betcha Bonnie & Clyde would have cleaned up with one of those. The pic looked amazingly like a 53 ford. Those design guys were way ahead of the game. Some of the other cars I looked at were a little closer to the truth although the 48 f100 seemed off by a hair or 2 with 351" and 275 HP. hmmmmm. It gives you an opportunity to email corrections to them. I'll start tomorrow, first thing.
BE different....ACT normal.
Small Block Ford Specs. Coleman396 Engine 1 04-03-2004 08:55 PM
Ford specs? 87442lover Engine 3 08-19-2003 09:34 PM
Sealed power Cam specs? 87442lover Engine 9 08-07-2003 11:35 PM
chevy 10 bolt rearends torgue specs fuman Transmission - Rearend 0 12-24-2002 10:26 AM
VETTE REAR END TORQUE SPECS reegeemon Transmission - Rearend 1 12-23-2002 02:32 PM
