Need specs on gk cam C2M 288-B - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 07:36 PM
Needing information on the intake and exhaust lift and duration and centerline on this General Kinitics cam. Also is it hydraulic or solid lifter valve adjustment? Thanks for sharing. Also it is in a big block chevy 396
Old 07-11-2012, 07:47 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
This thread may be of some help: General Kinetics Cams. Hopefully BOBCRMAN will see this and chime in.
Good luck!
camshaft, general kinetics
cam specs on a roller cam for a 416 stroker terry2012 Engine 1 01-21-2012 03:13 PM
cam specs srx_700 Engine 3 04-19-2010 07:15 AM
Need help with cam dynamics cam specs reimeracing Engine 3 01-29-2010 02:44 PM
need cam specs smokey power Engine 0 08-02-2009 02:44 PM
anyone have the cam specs....... mark anderson Engine 5 12-07-2003 03:00 PM
