Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Speedo Advice
Old 12-02-2012, 10:23 AM
cdminter59 cdminter59 is offline
Need Speedo Advice
Most aftermarket speed sensors will not work with factory speedometers. The speedometer sensor you have now is a 16 pulse sensor. I believe the factory speedometer sensor is a 8 pulse. What happened to the sensor from your 700R transmission? Did it have the sensor screwed to the speedometer gear housing?
