Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Speedo Advice
Old 12-02-2012, 12:35 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by cdminter59 View Post
Most aftermarket speed sensors will not work with factory speedometers. The speedometer sensor you have now is a 16 pulse sensor. I believe the factory speedometer sensor is a 8 pulse. What happened to the sensor from your 700R transmission? Did it have the sensor screwed to the speedometer gear housing?
Thanks, I forgot about the pulse business.
Check out this site for vss's driven by the speedo gear:
V-8 Vehicle Speed Sensors (VSS), Speedometers, V8 Conversions, Stealth Conversions
