Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Speedo Advice
Old 12-02-2012, 11:19 PM
Chevyman87 Chevyman87 is offline
Sensor on the 700r4 would have not worked as it was screwed to the speedometer gear housing. Also the speedometer gear housing was much bigger in diameter versus the bullet style speedo gear housing in the TH350. Someone recommended a unit made by Dakota digital (DAK-SGI5) but it was a bit confusing to figure out how to make it work. The only reason I have the part I do now is because I wanted to cover the speedometer gear housing hole with something more reliable than the factory plastic plug they installed in it. Does anyone have any experience with the Dakota digital part?
