-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Need square sockets (http://www.hotrodders.com/forum/need-square-sockets-92397.html)
oldsmo 06-24-2006 07:38 PM
Need square sockets
Where do you find the square sockets to use on motors with square plugs??
njbloodline666 06-24-2006 08:27 PM
snap on, if you are talking about square pipe plugs... if they are female squares they are usually 1/4. 3/8 or 1/2 so you can use a regualr ratchet or extension. for male squares, if you cant use an adjustable wrench..check snap on
oldsmo 06-24-2006 08:41 PM
I don't trust using the extensions anymore since I just stripped one out on a motor. I was just going to get a set and be done with it. Maybe some more heat too. :)
92redgt 06-24-2006 08:51 PM
S&K also makes them
hotroddr 06-25-2006 10:15 PM
square sockets
Just in case you haven't seen them before, they may appear different than you might expect- the ones I have aren't square but 8-sided stars. I'm only mentioning this in case you're not familiar with them, not trying to be an SA. Bill :)
KULTULZ 06-26-2006 12:02 AM
What you have is TORX.
Here's what he is after (and they are nice to have);
http://www.skhandtool.com/images/itemimages/19781.jpg
tbirdscott 06-26-2006 12:23 AM
I've got a set from craftsman, they are 8 sided.
njbloodline666 06-26-2006 01:15 AM
torx are 6 sided, 8 sided ones are called double square, they even make a tripple square, (12 points) i had to change the ign switch on a vw passat once, i needed a tripple square driver, i have never even heard of it..stupid german engineering
Kevin45 06-26-2006 03:16 AM
I think Bill is talking about an 8 point socket which is a square and another square turned 45 degrees. These are female sockets and can be used on the square shoulder of threading taps, etc.
http://buy1.snapon.com/catalog/OBJECTS/20700/20654.JPG
What Oldmo wants is a male plug socket used to take the plugs out of the side and front of the block.
Internal pipe plug socket
http://buy1.snapon.com/catalog/OBJECTS/49700/49648.JPG
External pipe plug socket
http://buy1.snapon.com/catalog/OBJECTS/49800/49709.JPG
Although an extension will work on certain occasion the pipe plug socket fits a little more closely than the extension. Also it is a good idea to heat up the plug with the blue wrench prior to removing it. They can be a real bear coming out at times especially if something like Indian Head was used on them.
Correct????
KULTULZ 06-26-2006 04:04 AM
Correct. The word stars threw me off. The eight points I have found only from WRIGHT. They can be used on both four point and six point fasteners.
I see you are a SNAP-ON participant. SNAP-ON has these also?
oldsmo 06-26-2006 11:50 AM
The pic is exactly what I am talking about. thanks
sbchevfreak 06-26-2006 01:16 PM
Snap on also makes the double square sockest, in impact and chrome finish. I have a set, use it rarlely, but really appreciate having it when I need it. :)
sha_ba_do_bang 06-27-2006 08:47 PM
they have everything!
if you got the money
hotroddr 06-28-2006 09:22 PM
square sockets
Thanks for the input and clarification. I bought a machinist's toolbox at a swapmeet many moons ago, and there were a bunch of 2-3" square tooling in different sizes, whenever I need an "outie", I stick these in the square sockets. Bill :)
